Engine light/loss of power/ not rev past 3k rpm
Old Feb 24, 2016 | 03:46 PM
Mrdrmini's Avatar
Mrdrmini
The other day as I was driving, I accelerated and the car started to sputter but regained power, soon after that it did it again as I accelerated, but this time the engine light turned on and the car shut off. Once turned back on the light remained on but now when I accelerate the car will sputter and at times shut off or rev but will not pass 3k and engine light is on also with the engine light that half full and half empty on the cluster. Any ideas what the problem is befor I take it in???? Thanks for your help
Old Feb 24, 2016 | 05:21 PM
AZdsrt's Avatar
AZdsrt
Could be a million different things. Get the code pulled and post it back here..
Old Feb 25, 2016 | 12:07 PM
nkfry's Avatar
nkfry
Get the codes pulled by a shop with a quality tool.
If you are in the cold it could be anything from a failing HPFP to ice in the intake.
But as stated, without codes there isn't much help that can be provided.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 26, 2016 | 01:40 AM
Systemlord's Avatar
Systemlord
Sounds like the HPFP, some report difficulty starting when cold starting in the mornings while others experience sputtering when trying to accelerate. Get those codes but don't clear them as they help in diagnosing your car and if you want Mini to pay for it do not clear the code.
Mini extended the HPFP to 120,000 miles or 10 years on 2007-2009 Mini Cooper S models, any other year and you're out of luck.
Old Feb 27, 2016 | 06:15 PM
Mrdrmini's Avatar
Mrdrmini
Sounds like the HPFP, some report difficulty starting when cold starting in the mornings while others experience sputtering when trying to accelerate. Get those codes but don't clear them as they help in diagnosing your car and if you want Mini to pay for it do not clear the code. Mini extended the HPFP to 120,000 miles or 10 years on 2007-2009 Mini Cooper S models, any other year and you're out of luck.
p1057 p1062 p0328 p105c these are the codes that popped up
Old Feb 28, 2016 | 01:49 AM
Systemlord's Avatar
Systemlord
Sounds like you have electrical faults for the first two codes, the P0328 is Knock Sensor Circuit High Input probably do to electrical problems and the last one is a mystery. Time to load test your battery, voltage readings taken at the battery don't usually prove helpful in most circumstances to determine a batteries health status. I wonder if it could be that simple, a dead battery?
Old Mar 1, 2016 | 09:40 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Might not be a bad idea to test out the battery at least, but it may be that you have something more serious going on.
P0328 Knock Sensor 1 Circuit High (Bank 1 or Single Sensor) or it could be 0x304B Knock sensor signal: Engine produces excessive mechanical noise or crankshaft outside tolerance (sensitivity)
Info - http://www.obd-codes.com/p0328
P1057 VVT Motor Supply Voltage (Bank 1)
P105C VVT Control Motor Tight
P1062 VVT Limp Home Request Full Stroke Position Reached (Bank 1)
Some info - https://www.northamericanmotoring.co...-bank-1-a.html
888.280.7799 | 6am - 5pm PST
Old Mar 1, 2016 | 07:45 PM
Sculsz's Avatar
Sculsz
Year & model????
boatman2500
Feb 5, 2016 07:53 AM
tennis_man
Feb 3, 2016 07:37 AM
nstabl
Feb 1, 2016 09:04 AM
supermini23
Jan 31, 2016 04:15 AM
Saltysalt
14
Jan 28, 2016 10:44 AM
