Fuel pump running after its shutoff R56S
Old Mar 13, 2016 | 11:35 PM
MidwayMountaineer's Avatar
MidwayMountaineer
Just bought my Mini about 2 months ago and occasionally after I shut it off the fuel pump continues to run.....It always quits after I start it back up and shut it off again....What causes this?? Do I need a new relay???
Old Mar 14, 2016 | 08:29 AM
The main fuel pump or the HPFP in the front ?
Main fuel pump 16112755084
https://www.ecstuning.com/Search/SiteSearch/16112755084/
HPFP Front:
https://www.northamericanmotoring.co...r-r56-jcw.html
Fuel pump issues:
https://www.northamericanmotoring.co...ump-relay.html
Old Mar 14, 2016 | 08:43 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Are you able to pinpoint the sound location?
Sometimes the Aux Water Pump will run briefly after shutdown to cool turbo bearings....
Old Mar 14, 2016 | 08:46 AM
That was my next thought, aux water pump noise, think it was the fuel pump up front.
Old Mar 14, 2016 | 03:25 PM
MidwayMountaineer
Sorry yeah should have been more specific....I'm not familiar at all with these cars (need a service manual)...I assume it is the main fuel pump, the sound is coming from the rear passenger side...I haven't really left it running to see if it shuts off (I assume it will since its not something that runs every time I shut the car off)....Just trying to pinpoint the problem and address it....
Old Mar 14, 2016 | 03:30 PM
MidwayMountaineer
On a side note, are these Ebay service manuals worth buying
http://www.ebay.com/itm/MINI-COOPER-...FWcSHW&vxp=mtr
Old Mar 14, 2016 | 09:47 PM
timski's Avatar
timski
On a side note, are these Ebay service manuals worth buying http://www.ebay.com/itm/MINI-COOPER-...FWcSHW&vxp=mtr
I bought one off of eBay and was disappointed.
It was mostly 1gen manuals. Some TIS stuff mixed in and a 2nd gen supplement.
The seller offered to refund the $10 but I didn't want waste my time sending it back.
I need the full TIS for my 2011 JCW.
I gave up.
Old Mar 15, 2016 | 08:06 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you go to our site under MINI and click the tech info (tab at the top) and then select the R56 articles you'll see a bunch of free sources that you can use to troubleshoot or fix things on your R56. They're pretty useful if you don't want to buy a Bentley Manual HERE. You might be able to find a used one floating around in the marketplace. I see them pop up every now and again.
888.280.7799 | 6am - 5pm PST
Old Mar 26, 2016 | 12:19 AM
renchjeep's Avatar
renchjeep
MidwayMountaineer, there is also a vacuum pump that runs at certain times in order to check the fuel tank and EVAP vent system for leaks. I have heard odd sounds coming from the right rear quarter panel, in front of the wheel, at times after shut-down. It is just the vacuum pump, doing checks for leaks. It may happen just after shut-down, or may wait to run the test. Does it sound like a series of an electrical pump running, then shutting down? That is what I have heard when the vacuum pump operates. Scared me at first, but most cars since 2000 or so have it. Some are more noticeable, some less. MINI's being as small as they are, pretty sure you will hear it, especially given the location. EVAP tests will only run when fuel level is between about 3/4 and 1/4 tank. See if that coincides. I am willing to bet that it will.
Old Mar 27, 2016 | 12:52 PM
MidwayMountaineer
Awesome! Thanks for the reply I took it by a sip that works on them frequently and he told me that's what it was!!!
Old Mar 28, 2016 | 01:39 PM
Makes a noise every one in a while to prime, and does it right before you get in the car to unlock the doors also.
Old Jun 25, 2022 | 07:40 PM
minivirginia's Avatar
minivirginia
Fuel pump still running
I have a 2008 Mini Cooper S convertible and noticed this hum coming from the left rear end when the car is off and the key out of the ignition.
I have pulled the fuel pump relay from under the hood and replaced the 6yr old battery. The only way to make it quit humming is to pull the 20 amp fuse from under the dash.
Any ideas what it could possible be?
Ignition switch or the ECU?
Old Jun 25, 2022 | 08:05 PM
minivirginia
Old Jun 27, 2022 | 07:39 AM
Sounds like a short or the pump is bad. You have an R52, not an R57(Gen 2 MINI with the HPFP). That system does not have the HPFP, you have a short in the system.
I bet the Relay is bad or the fuel pump needs replaced as its locked on. Please post in the R52 area so people dont get confused with the R56.
MazMini
Nov 19, 2016 10:09 PM
countrymanall44
22
Apr 19, 2016 09:01 PM
Jason04
Feb 29, 2016 08:16 AM
thebombardier
Feb 19, 2016 03:02 PM
otto_my_way
Feb 19, 2016 02:14 PM
