2010 Clubman S- Disconnected Battery, now electrical issues
Old Jan 23, 2016 | 10:14 PM
marshallpre1's Avatar
marshallpre1
Good evening fellas,
New guy here, needed help figuring out what's wrong with my friends 2010 Clubman S. Her valve covers were leaking so I decided to help her out and do it for her. I've done it several times before, but mostly on Japanese import cars. Whenever I work on any car, I disconnect the battery as the first step. So that's what I did. I ended up completing the valve cover gaskets, doing an oil change, and the pcv vent hose. I plugged the battery back in. When she was leaving she noticed that her head lights and rear lights were stuck on, but the dash was not illuminated, the turn signals did not work, or the hazard lights. Windows also don't roll up or down. Everything else seems to work (radio, AC, interior lights, etc). There is an image of a mini on a lift, which indicates that it might be due for service, but no other warning lights. The car is not drivable in this condition for safety reasons. Does anyone know what is wrong with it? Did I blow a bunch of fuses out of nowhere? One thing she did tell me is that her reverse light bulb needed change.
I am perplexed. I've never had such issues with any car. Any advice or help is appreciated.
EDIT upon more research: FRM issue? What is this thing? We didn't even touch it. I'll try charging the battery overnight to see if it makes a difference tomorrow. Battery has 12.6V. seems fine
https://www.northamericanmotoring.co...solutions.html
Jeremy
Old Jan 26, 2016 | 11:28 AM
miniuy's Avatar
miniuy
Hi,
yes it seems it is a FRM related issue.
First of all I would try by disconnecting the battery again and removing the reverse lights bulbs.
When reconnecting the battery, if it was not the solution you should check the FRM health though the OBD port (responding, not responding).
There is not a way to reset it nor a fuse to change for it, but, something else could be crashing the FRM (bad cable, etc).
Old Jan 29, 2016 | 07:56 PM
marshallpre1
I got NCS expert from my friend. I have no problem connecting to CAS, but FRM has issues connecting. I posted in several other threads, but no help yet.
New FRM is like $1K +programming from the dealer... This is insane.
https://www.northamericanmotoring.co...ml#post4169554
Old Feb 2, 2016 | 11:33 AM
miniuy's Avatar
miniuy
Sorry for saying this but if you can't communicate with the FRM, it seems is the time to replace it.
If your are a NCS Expert user, the FRM replace can be done for you, in 30 minutes (10 minutes replacing the hardware, 10 minutes coding and 10 minutes posting your success here )
You need 2 things:
- Buy an used FRM module compatible with your current FRM module
- Take the VO listed in the CAS module to program the "new" FRM module (FRM module is the CAS backup too!).
There is not other additional stuff to do !
Old Nov 6, 2023 | 05:33 PM
karebare's Avatar
karebare
May be your footwell module
Jeremy
hey Jeremy I had the same problem with my clubman. I had it all taken apart for a freeze plug and when I finally put it all back together and turned it on the windows didn’t work, lights, etc. I had to get my footwell module reprogrammed. I figured out after the fact that there is a recall on them. Good luck!
studio47
Dec 4, 2015 08:46 PM
Beau B
R60/R61 Stock Problems/Issues
Dec 4, 2015 01:12 AM
Miniwaukee
Nov 28, 2015 10:34 AM
DBHawk
Nov 24, 2015 07:40 PM
jeffreyevens
Nov 24, 2015 06:49 PM
