Temperature sensor "recall" - cold start on hot day
My 2010 R56 LCI MCS is suddenly having problems with a cold start on a hot day (in the 90s Farenheit). The dealer says this is a known issue and a faulty temperature sensor is the subject of a replacement program by MINI.
The engine starts but just chugs as if it's about to stall. Sometimes it comes good, sometimes it needs several attempts then it fires (in a cloud of grey smoke
). No warning lights or message. This apparently is the typical set of symptoms.
Even with the turbo fan that was a recall in other countries, MINI here in Australia just rolled it out through normal servicing or on request
. They're doing likewise with the temperature sensor
so it might be a recall elsewhere; if not, it's worth requesting the replacement if you're somewhere with hot weather.
And MINI Australia has run out of the replacement part so mine's on order from Germany
- hopefully getting here before I head off to hot inland areas over Christmas!!
). No warning lights or message. This apparently is the typical set of symptoms.Even with the turbo fan that was a recall in other countries, MINI here in Australia just rolled it out through normal servicing or on request
so it might be a recall elsewhere; if not, it's worth requesting the replacement if you're somewhere with hot weather.And MINI Australia has run out of the replacement part so mine's on order from Germany
Thanks. My starting problem is only for cold starts (ie first start of the day) on a hot day, but I get the hesitation and slow warm-up you mention.
Thanks for the info - it's encouraging to know the fix really works.
Kimolaoha
Jul 5, 2023 01:04 PM
PSIChocolate
Aug 13, 2015 12:46 PM
