Boost leak?
Old Sep 14, 2016 | 12:06 PM
SpuuDy's Avatar
SpuuDy
Boost leak?
Hello all you, I have a Alta accessport on my car, I was running a stage 1 92 octane tune in my car and was getting 18-19psi. My car started to run a little rougher at idle though due to the gas I as running through it. So I changed the tune to stage 1 91 octane until I got better gas to run through my car. When I finally got the better octane to run, I returned to the 92 octane tune and now I'm only seeing 14.6psi Max. Would you guys say that it's due to a boost leak or it's the computer?
Before I got the tune on my car I was running 12psi and 14psi with over boost so the tune is really not doing much for me now.
Thanks!
Old Sep 14, 2016 | 04:44 PM
Euler-Spiral's Avatar
Euler-Spiral
I would guess ECU, there is adaptive code, try ECU reset, or if its same as before is tune loading, It may also relearn knock sensor adjustments in 300 miles. pedal speed is an input try foot up off throttle then down. Cant always clear fuel in one shot add cleaner booster. should go to 20psi for you up in higher rpms do you use the whole range once in a while
Old Sep 14, 2016 | 05:29 PM
SpuuDy's Avatar
SpuuDy
I ran a 104 octane booster and also fuel cleaner to a 16 gal mix... Your saying like floor it then let off and floor it again?
Old Sep 14, 2016 | 06:36 PM
Euler-Spiral
Ok octane should be good. The electronic throttle pedal registers angle change over time it doesnt even really relate to a throttle body butterfly valve position. when you log it you see a sine-wave like graph. it takes speed vs ignition fuel etc and guesses what you want, so wide open throttle is relative to how fast you press on the throttle giving different map paths,,,,,
so if your foot is moving before it gets to the pedal it sees a fast spike and may interpret it as a need for max mapped response. No need to try more than once but work up to anything aggressive it could suddenly get with it and take off.
There are electronic aides to remap or amplify the pedal inputs, Sprint booster I think is one also tuners can adjust some of this, but because engines are all slightly different and change as they age or get different fuel grades, there is adaptive code to compensate and just plain adaptive run modes, Yes its all tied together and if for some reason temps or o2 readings or knock signals dont match up the ECU backs off,
In the other direction if you spend time running around the track at 6500rpm and everything is working it will stay in a more responsive state for awhile Im not sure of the time to reset by itself but the 300 mile bit is something I kind of notice
Old Sep 14, 2016 | 06:48 PM
SpuuDy's Avatar
SpuuDy
Okay, I think I understand what you are saying with the throttle position and mapping, the more aggressive the acceleration of the pedal, the more aggressive the mapping associated with WOT. I have used the ap to reset the ecu a few times and I think I did it just as I re loaded the tune on my car again, so maybe I should wait a few hundred miles and see what psi is then. Also, here in Missouri our weather is changing so maybe ambient temp has something to do with it (even though it's getting somewhat cooler)?
Old Sep 14, 2016 | 07:26 PM
Euler-Spiral
Cooler air is denser and lowers intake air temps so you get better power. I actually keep reporting my cylinder heads ect. to use less boost psi, boost psi is a measure of resistance to air flow check your maf readings 1.6L running 1psi and 40lb/min at 5000rpm would be out of this world,,,,,, yes I get long winded sorry
Old Sep 14, 2016 | 07:36 PM
SpuuDy's Avatar
SpuuDy
You're fine with being long winded as long as it's full of information ha ha. But i wonder if a 10degree drop in temps would cause a 4-5psi drop. The car does feel slower to. I'm going to check the maf sensor to see if it's gummed up and see if I can't log that also. If none of this works then I might just have to try to go to stage 2 ap tune (after supporting mod) and see what that does. Do you know if any one offers support for the Accessport?
Old Sep 15, 2016 | 10:15 AM
SpuuDy's Avatar
SpuuDy
I might have just solved my problem. When you load a tune/ reflash ecu with the ap it'll take you to a screen instructing you to turn off the car and wait 10 seconds. I am assuming this is so the tune can load. When it gets to that screen I have just been turning it off and then just going about my day.
Edit: this did not fix it, still the same..
Old Sep 17, 2016 | 01:23 AM
NJ Mini's Avatar
NJ Mini
How many miles do you have on the car?
Old Sep 17, 2016 | 03:56 AM
SpuuDy's Avatar
SpuuDy
91600. The boost levels are starting to go up day by day. This morning on my way to work I was getting 17psi. I'm due for an oil change though so I'm not going to try to hot rod my car
E46M3LOL
44
Mar 4, 2019 09:56 AM
fixthedoor
R55 :: Clubman Talk (2008+)
Sep 14, 2016 07:03 AM
eviasanders@yahoo.com
Sep 13, 2016 12:34 PM
jrosa
Sep 11, 2016 06:42 PM
NEPABob
Sep 10, 2016 04:16 PM
