Long crank to start after filling gas tank, and stumbles then runs fine.
Old Dec 25, 2016 | 03:39 PM
jetsr6's Avatar
jetsr6
2007 MCS 112,000 miles. When I start the mini after getting fuel it will take a lot more cranks until it starts and stumbles. After that it starts fine every time even after a week or more. I did find the purge valve bad and replace but still hard start after fueling/gassing up. I've replaced the fuel filter and have checked lines in tank and replaced fuel pump with new. The HPFP was replaced under the 10 year 120,000 warranty. The purge valve was used but sounded good with test on ISTA/D and couldn't blow through it.
My next step was to get a five gallon fuel can fill the Mini with the purge valve disconnected.
Anyone have any thoughts on this?
Old Dec 26, 2016 | 04:27 AM
MiniToBe's Avatar
MiniToBe
Do you hear the low pressure pump priming? It sounds like there isnt enough pressure build up or you are losing it some where. Is the cap tight and the tank lid under the seat also tight?
Old Dec 26, 2016 | 04:52 AM
jetsr6's Avatar
jetsr6
Yes I hear pump priming. It was the original fuel pump so I went ahead and changed it. And it did the same thing(hard start after filling up with gas) before and after fuel filter change and pump replacement.
Old Dec 26, 2016 | 08:13 AM
minirab's Avatar
minirab
Do you try to get every last drop of fuel in your tank after the nozzle "clicks"? I had the
same problem as you with another car I owned. I found out that every car has an over-
flow canister that catches any fuel that the tank can't hold. When this canister gets full
you will for whatever reason have an initial hard start. Don't ask me why.
Old Dec 26, 2016 | 08:48 AM
jetsr6's Avatar
jetsr6
Thanks, I bought it used this past summer not running so the last owner mite have.
Old May 13, 2017 | 01:19 AM
jetsr6's Avatar
jetsr6
Replaced purge valve under intake manifold, problem fixed.
Old May 15, 2017 | 09:17 AM
thefarside's Avatar
thefarside
I'm confused. Do R56s have two purge valves? In your post from 12/25/16 you said you had replaced the purge valve to no avail.
Please clarify.....
Old May 15, 2017 | 12:47 PM
jetsr6's Avatar
jetsr6
It was a used one that didn't work. When I installed a new purge valve that's what fixed it. There is only one purge valve and it's under the manifold.
Old Mar 20, 2018 | 02:39 PM
munkmunk's Avatar
munkmunk
I need to replace the purge valve (part number 13907624538) on my wife's 2010 Mini Coupe. You state it's located under the intake manifold. Does the intake manifold need to come off to get at it?
Old Mar 20, 2018 | 02:49 PM
jetsr6's Avatar
jetsr6
No the manifold doesn’t need to come off but it will be extremely difficult to disconnect everything. Because you can’t see it. If you do remove the manifold there is a 10 mm bolt underneath the throttlebody which you can’t see that either you can access it from the passenger side from above. The manifold doesn’t need to be completely removed just lifted off the head and tilted back to access the purge valve.
Old Mar 20, 2018 | 04:37 PM
munkmunk's Avatar
munkmunk
Thanks. Hmm. I guess I need some detailed instructions on how to remove the intake manifold. Can someone point me to a thread? I’m used to the old school 50’s and 60’s cars. They don’t have all these plastic panels hiding stuff like in these cars. Ugh.
Old Mar 20, 2018 | 05:20 PM
jetsr6's Avatar
jetsr6
Here you go.
https://www.pelicanparts.com/techart...eplacement.htm
Old Mar 20, 2018 | 10:47 PM
munkmunk's Avatar
munkmunk
Thanks. So far I've got the airbox off. Found a thin black hose under the big air intake inlet hose on the right of the engine (facing the engine from teh front of the car). One end is connected to a thin pipe, but the other curved end isn't connected to anything. You can see the thin black hose in center of this photo:
Should it be connected to something or is it some kind of drain?
