Multiple codes, possible hpfp issues?
Old Sep 19, 2016 | 05:31 PM
weldboy's Avatar
weldboy
2012 r56s hesitates on startup if it's sat for more then a few hours. Doesn't do it every time. 47k on car. Ran the codes with dashcommand and a kiwi2. any ideas? Thanks for your help
Old Sep 19, 2016 | 07:59 PM
randeez's Avatar
randeez
That would be a pretty good guess , show a gauge for and watch fuel rail pressure next cold start with dash command. Fuel rail should show 800+psi at idle , while mine was having trouble it wouldnt build more than 100psi on cold starts
Old Sep 20, 2016 | 10:43 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Definitely sounds like that might be your issue. You can check the high pressure system on turbocharged models using a MINI scan tool. We go over this in our tech article if you want to test it. It's under MINI > Tech Info (tab at top) > R56 articles and then scroll down to Fuel Injection and it's the 2nd to last one in that section. Look at figure 10 in the article for specifics. If you determine this is your issue, I have seen N18 owners get theirs replaced under Service Bulletin # 010116. May be worth calling your dealer and checking in on it.
http://www.pelicanparts.com/catalog/..._pg2.htm#item6
888.280.7799 | 6am - 5pm PST
AJoelj84
Dec 24, 2017 09:58 AM
vincedprince
Apr 24, 2017 11:46 AM
weldboy
Tires, Wheels, & Brakes
12
Dec 7, 2016 10:51 PM
weldboy
Sep 18, 2016 03:51 PM
solskjaer1999
Sep 14, 2016 07:25 AM
