Insert Navigational DVD
Old Nov 11, 2010 | 04:46 PM
bugeye1031's Avatar
bugeye1031
Moderator
Our 2007 Cooper is having an occasional problem when we use the Nav. It randomly stops and tells us to insert navigational dvd right in the middle of the directions. The only way that we can figure out how to get it going again is to pull over and turn the car off and start it up again. I did a search and couldn't find anything - any suggestions?
Old Nov 12, 2010 | 10:22 AM
t0m's Avatar
t0m
I don't have the nav system, but my guess would be that its the result of disc read errors from the nav dvd. Its probably a result of either scratches on the dvd, or a dvd drive that is failing. You should be able to eject the dvd and examine it. If there are any scratches, you should be able to see them by looking at the dvd at an angle under direct light.
Old Nov 12, 2010 | 03:09 PM
CarJon's Avatar
CarJon
There are DVD cleaners available - probably worth cleaning the disk
Old Nov 12, 2010 | 07:19 PM
56rfixr's Avatar
56rfixr
There is a bulletin for this, it is an issue with the nav drive, take it in to your dealer and they replace the nav disc drive.
OutMotoring
Nov 16, 2015 07:04 AM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
