:: ECS Tuning :: More Ziza LEDs :: Euro Parcel Shelf is BACK ! Yes Driver Side !
MINI R50 R53 Euro Parcel Shelf : Driver side
This Genuine Parcel Shelf is a fast and easy way to add extra storage for small items.
Straight from the Euro market, it comes in panther black to match the original dash panels.
A spare rectangular hole in the panel accepts a stock switch so you can control any accessory you choose.
Get the full kit with the blind plate and insert rubber for the full MINI experience.
Get the Euro look!
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE For Euro Parcel
MINI R52 Euro Parcel Shelf : Driver side
Get the Euro look!
Fits:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE For the Euro Shelf
Transmission Essentials For Your MINI R56
Your MINI transmission is a collection of parts that must each be functionally sound for the gearbox to do its job.
It follows then, logically, that when attending to a particular transmission issue, the strength of the weakest part determines the end quality of the system.
For this reason, ECS offers several complete Auto Trans Service Kits for your MINI, as well Clutch Masters Clutch Kits.
Do It Right.
Fits:
R56 MINI Cooper S / JCW (2007-2013)
Click HERE For transmission options
Pierburg Pressure Converter For Your MINI R60/R61
Feeling a little sluggish?
The performance of your MINI thrives on the ability of the turbocharger. Even the smallest of pressure leaks can slow you down and turn your check engine light on.
Don't let any of that power get away with a worn pressure transducer. A common problem with turbo control systems, this Pressure Converter from Pierburg will bring your boost levels back to where they should be, and help get rid of that annoying check engine light!
Now more affordable than ever from the OEM manufacturer, fix vacuum leaks and boost problems with one simple repair
Under Pressure?
Fits:
R60 MINI Countryman S/SX/JCW (2011+)
R61 MINI Paceman S/SX/JCW (2013+)
Click HERE For Options
Ziza LED Performance Lighting | MINI R55 Clubman
You won't believe the difference an LED lighting package makes in your car until you see it with your own eyes. LED illumination is a far brighter and friendlier light, crisp and clean, especially when compared to the dingy yellow glow from conventional filament style bulbs.
Now you can do a complete LED conversion using our MINI LED Interior Lighting Kit. It contains all the LEDs needed for a total lighting upgrade. No need for guesswork or complicated ordering of individual bulbs.
Ziza; Light Years Ahead
Fits:
R55 MINI Clubman / S / JCW (2011-2014)
Click HERE For Ziza kits
Ziza LED Performance Lighting | MINI R50 R53
Fits :
R50 MINI Cooper (2002-7/2004)
R53 MINI Cooper S / JCW (2002-7/2004)
MINI R58 Coupe' Ziza LED Performance Lighting
Fits:
R58 MINI Coupe' /S/JCW (2012+)
Click HERE For Ziza options
MINI R59 Roadster' Ziza LED Performance Lighting
Fits:
Fits:
R59 MINI Roadster /S/JCW (2012+)
MINI Paceman Ziza LED Performance Lighting
Now you can upgrade your running lights and and license plate lights to clean, bright Ziza LED's.
Fits:
R61 MINI Paceman /S/SX/JCW (2013+)
Jan 4, 2019 12:51 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
