Trunk latch is constantly releasing...
Old Dec 12, 2010 | 06:25 PM
Wilco's Avatar
Wilco
So I found my mini with a dead battery last week, and after recharging the battery I'm finding my trunk release is constantly opening. I can hear a relay clicking somewhere near the right rear wheel well, but I'm not sure if it's related (it seems to click both when the latch randomly opens, but also when it doesn't).
Even with the car completely shut off this will continue until the battery is dead.
Has anyone had a similar issue before? Any idea what it might be?
Old Dec 12, 2010 | 08:11 PM
JustinGTP's Avatar
JustinGTP
the clicking near the right wheel well is most likely something to do your fuel pump and is normal.
now, are you saying that it is releasing by itself?
Old Dec 12, 2010 | 10:00 PM
Tortatamer's Avatar
Tortatamer
If your car is still under warranty you should take it in. The dealer may have a tough time trying to duplicate it so it may help trying to find out if it happens only when the car is on or both when on and off. The more info you can get on it the better since it may not happen when you take it in. Good luck with it!
Old Dec 12, 2010 | 10:02 PM
Tortatamer's Avatar
Tortatamer
Kinda sounds like the switch
Old Dec 12, 2010 | 11:36 PM
Wilco's Avatar
Wilco
It actually seems to happen only when the car is off (I left it on outside for about 10 min and it never unlatched. As soon as I turned it off and locked it, I heard the trunk unlatch before I made it inside.
Old Dec 16, 2010 | 06:39 PM
gawannamini's Avatar
gawannamini
The latch on my 2009 convertible's trunk would sometimes have a mind of its own. I would hear clicking noise behind the right wheel well as I believe that is where the relay is located. Dealer found that one of the limit switches in the latch was just barely making at times. They replaced the latch under warranty and the problem was eliminated. Good luck.
OutMotoring
Mar 3, 2017 06:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
FatherG
Sep 29, 2015 02:47 PM
silence2-38554
Sep 28, 2015 12:19 PM
daviday
Sep 25, 2015 01:31 AM
