help finding screws for Pillars on center console
Old Nov 15, 2010 | 05:22 PM
WizardEyes's Avatar
WizardEyes
not sure where to post this but while doing a boost gauge/volt gauge install i found that the previous owner had somthing else installed inside the dash becuase i found a loose wire that was cut and folded up behind the front parcel shelf that was atleast 5 feet long as i searched i found the the Pillars in the center were also missing 2 screws on one side and one of the other upon further searching i found that one of the screws from the side missing 2 screws was actualy broke off inside one of the little Blue clips they screw into, does anyone have a part number for the screws on them as well as the little blue clips inside that they screw into?? i really need em because i want to put a kuda mount for my iphone in there. any help would be greatly appriciatied
Old Nov 16, 2010 | 07:31 PM
WizardEyes's Avatar
WizardEyes
anyone????
Old Nov 16, 2010 | 08:03 PM
56rfixr's Avatar
56rfixr
Little blue clips soudn like a first gen (r50-53) dash. Depending on your dealer, they should stock them or should be able to order them. Also IIRC the hardware for the pillars are 2 different sizes, left being t30 and right being t25.
Hope that helped.
Aug 14, 2015 11:13 AM
xraycat
Aug 12, 2015 02:36 PM
Aug 12, 2015 01:24 PM
