Rough morning start, ODBII codes inside. Possibly HPFP??
Old Aug 19, 2017 | 05:06 PM
jacobarber's Avatar
jacobarber
2009 MCS, 107k miles, have had the HPFP replaced twice already.
I've had some mornings lately where starting is difficult (~65f outside). Sometimes it takes several attempts and then runs just fine, sometimes it takes several attempts then stalls if I don't keep RPMs above 1k for a min or so (less frequent), and sometimes it isn't troublesome at all.
My bluetooth ODBII reader is throwing the following codes:
  • p3149 Cylinder 1 High Pressure Injector High Side Circuit Low
  • p3152 Cylinder 2 High Pressure Injector High Side Circuit Low
  • p3155 Cylinder 3 High Pressure Injector High Side Circuit Low
  • p3158 Cylinder 4 High Pressure Injector High Side Circuit Low
Searching for any of these codes does not return anything definitive, so I'm hoping someone here has better investigative abilities or experience that can help.
Thanks much.
Old Aug 21, 2017 | 06:41 AM
MiniToBe's Avatar
MiniToBe
your guess is probably right on! it seems that the pump design is bad to begin with even when new.
on another note, how is your battery? it could be low on juice.
Old Aug 20, 2021 | 05:08 AM
Collin Piette's Avatar
Collin Piette
I’m getting the same codes on my 2010 clubman s. Did you ever figure out what was causing the codes?
Old Aug 20, 2021 | 07:23 AM
thefarside's Avatar
thefarside
Codes seem to be caused by a low power supply or a wiring issue, possibly a faulty DME/ECU
https://www.autocodes.com/p3152_mini.html
sub3622
Aug 27, 2021 10:45 AM
Hairy W Bush
R55 :: Clubman Talk (2008+)
Jul 17, 2021 10:26 AM
genik
Nov 12, 2018 10:59 PM
AFN704
Jan 15, 2016 07:53 AM
doubledown808
Sep 17, 2014 06:50 PM
