P2187 error, what is it?
Old Aug 7, 2013 | 09:35 PM
genik's Avatar
genik
Its the second time i get an engine light on, diagnose and see that its the P2187 error, any clue what that is for?
Old Aug 7, 2013 | 09:57 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I won't tell you the answer - but I will tell you where you can find it, here: http://www.*********************/library/all-about-mini-coopers-17/ecu-codes-chart---2nd-generation-mini-102/
replace the *****s with the name of that other forum site about minis, motor ing alliance dot com (seems to be some filtering going on for posting links, LOL.)
That list ought to be in a sticky here on NAM.
Old Aug 7, 2013 | 10:19 PM
Braminator's Avatar
Braminator
Well since your link does not work and you did not help, let me
The code P2187 system too lean at idle bank 1.(Too lean at idle= not enough fuel per the amount of air when the engine is idle.) Possible issues MAF, low fuel pressure, vacuum leak engine, failed heated oxygen sensor bank 1
Also could be the High Pressure Fuel Pump is failing
Old Aug 7, 2013 | 10:21 PM
Braminator's Avatar
Braminator
Should also mention depending on mileage it could need a carbon cleaning.
Old Aug 7, 2013 | 10:45 PM
squawSkiBum
Moderator
of course the link doesn't work (thanks to the forum SW filtering out certain names), read the clue underneath.
Old Aug 7, 2013 | 11:57 PM
genik's Avatar
genik
Thanx guys
1. Braminator, from all those options you posted, from which one do you recon i should begin checking? I suppose i should begin from the cheapest but what would that be?
2. Carbon cleaning? How do i do that? is there some guide/tutorial around?
Old Aug 12, 2013 | 09:59 PM
Corryszam's Avatar
Corryszam
Originally Posted by genik
Thanx guys
Hello any luck I just had my CEL turn on and got the same code and don't have a lot of cash right what did u end up trying and what worked mini wants 87 bucks to tell me!
Old Aug 12, 2013 | 10:41 PM
genik's Avatar
genik
My CEL is still on, so im not using the car (going to work by bus) until i find the time and the extra cash to check the issue! Braminator or anyone else haven't replied to my last post so i guess im stuck.
Corryszam whats the mileage on your car? what model is it?
Old Aug 12, 2013 | 10:52 PM
Corryszam's Avatar
Corryszam
2008 MCS 44k I have dropped 4k in last year on timing chain mess a turbo return line and a brake booster I really hope that this isn't another labor intensive issue I was fine until warranty expired and then 22 days later timing chain went and its been downhill from there and the dealership here I don't know if I really trust and I hate to say that
Old Aug 13, 2013 | 09:06 AM
Braminator's Avatar
Braminator
You need to be looking mainly at the HPFP and dirty injectors IMO. Do you have an after market rubber flexible air intake hose? These can intermittently cause that code to be thrown. I would check also the intake tubes and intercooler tubes.
Unless you are mechanically inclined I would take it to a MINI mechanic or the dealership.
I am betting it is your HPFP though.
Old Aug 13, 2013 | 12:36 PM
genik's Avatar
genik
What is the HPFP?
Oh ok a friend just told me .
So Bram you are referring to the High pressure fuel pump, ok but does it make any sense the fact that the CEL turned off and then after a few days it turned back on again? I mean if it was the HPFP, the CEL should never turn off, am i right? Aren't issues of the HPFP permanent if they go bad?
Old Aug 13, 2013 | 01:03 PM
Braminator's Avatar
Braminator
Your pump can be going bad and cutting in and out.
Old Aug 13, 2013 | 03:54 PM
genik's Avatar
genik
What other signs that something is going wrong should i have if the HPFP has gone bad?
Old Aug 13, 2013 | 04:20 PM
danjreed's Avatar
danjreed
Lack of power, hard starts..
Old Aug 13, 2013 | 08:09 PM
nrfitchett4's Avatar
nrfitchett4
unfortunately other members have had problems with their HPFP and their mini dealers refused to even look at it until after a carbon cleaning... Good luck.
Old Aug 14, 2013 | 06:52 AM
Corryszam's Avatar
Corryszam
So I drained gas tank down to 2 bars then added a bottle of 104 with engine cleaner then drive for 50 miles then shut off engine light and then I filled up with 95 octane from a race shop and then drove 100 miles and so far so good no light but its still early
Old Dec 28, 2013 | 11:42 AM
hlamin's Avatar
hlamin
Hi everybody.I have the same errors. P2187 via OBD scanner and 2785 via BMW DIS.Also i saw that additive and multiplicative correction of O2 sensors are very high (6.8% and 1.08) They start to increese after i reset rhe codes and become to these values after one minute. After additive correction reach 6% the engine fall to safe mode and power loss after 5rpm.Did anyone fix this issues?***
Old Dec 28, 2013 | 12:57 PM
genik's Avatar
genik
So guys, i haven't fixed it yet but it certainly seems to be an oil burning/leaking issue. Spark plugs are in a very bad condition so i guess that indicates a bad combustion. I also had a look to see inside the piston chamber with a camera and on the top of the pistons there were oil drops and burned oil, so i guess this oil leakage there could mean bad piston springs. But these are just a first indication, i guess ill be able to see for certain in a few days when ill take the car in for checking!
Old Dec 28, 2013 | 01:32 PM
hlamin's Avatar
hlamin
Genik, do you have DIS or INPA?
I want to ask you to check additive and multiplicative corrections of lambda(O2) regulation.
Spark plugs in normal condition in my case.
Ventilation of fuses in carter is one of posability reasons of this issue.
Aslo check here
I tried to disconnect this valve. If engine is hot - all well, if engine is cold - it work bad, a lot of misfire. I think disconection of this valve switch off lamda regulation, because while it disconected correction did not increese.
Old Dec 28, 2013 | 01:39 PM
genik's Avatar
genik
What are DIS and INPA? Im sorry if i gave you the impression that im a tech expert, i know nothing of engines n stuff, i just transfer what i hear from techs.
Old Dec 28, 2013 | 01:47 PM
hlamin's Avatar
hlamin
I do not think so) if you have a MCS you will be a expert)
DIS or INPA is BMW diagnostic software. It give a lot of info for diagnostic.
I provide here a screenshot with error from INPA, sorry it in german. And another in russian that show corrections)
Old Jan 20, 2014 | 05:08 AM
hlamin's Avatar
hlamin
Hi all,
I replaced HPFP yesterday and it didn't fix this issue. Additive correction still increesed too much and error appears again. But multiplicative correction now near the 1.
As you can at the pic below:
Multiplicative it is "множительная", additive it is "суммирующая"
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
11
Sep 30, 2015 02:11 PM
dutchhome
Sep 30, 2015 07:17 AM
ericf1993
Sep 26, 2015 03:58 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
