Coolant leak help
Old Nov 4, 2013 | 10:24 AM
KarKare's Avatar
KarKare
Coolant leak help
I have a 2009 JCW clubman approx 75k miles, coolant leak is coming from the driver side, more coolant leaks out when engine is reved. I know not the best pic but someone might be able to tell me where its coming from and the fix. Thanks
leak seams to be coming from where the two pieces meet, i believe theres a gasket between the shinier piece meets the other
Old Nov 4, 2013 | 10:54 AM
kemopots's Avatar
kemopots
That looks to me like your starter, but it is tough to tell with little reference. I would guess a thermostat housing as the source of your leak. this is a common area where the coolant will leak from. You can do a search here on NAM and find plenty of other threads about this problem.
Also, how much coolant are you losing?
Old Nov 4, 2013 | 11:09 AM
KarKare's Avatar
KarKare
yeh poor pic, i had a search around seems like it could well be the housing. well i was under the car and had someone step on the pedal, it would **** out, The cars under warranty so i guess they can deal with it
Old Nov 4, 2013 | 11:25 AM
Yea that's most likely the thermostat housing and leaking down the backside of the engine. It might be leaking lower on the backside of the housing so its either pooling on the transmission and falling off the back, or following the seam on the lower half of the thermostat housing and fall down.
Here is a link where it is discussed:
https://www.northamericanmotoring.co...t-leak-or.html
With that you can check for other locations that would have them also look at.
Thanks and good luck .
Old Nov 4, 2013 | 06:46 PM
Jeeper42's Avatar
Jeeper42
Thermostat housing is on the passenger side. Water pump is on the driver side. There is a plastic pipe that hoses from the metal water pump housing that is right above the starter. It has a small O ring on it. Most likely either the O ring is leaking or the pipe itself is cracked (which is what happened with mine). The plastic becomes brittle and that leads to failures. Really poor design if you ask me.
Old Nov 4, 2013 | 06:49 PM
Jeeper42's Avatar
Jeeper42
Check either ECS tuning, or Mini of South Atlanta for replacement parts. ECS has really good pricing.
Old Nov 4, 2013 | 08:16 PM
Jeeper42's Avatar
Jeeper42
Never mind what I said. I'm obviously dyslexic from lack if sleep. I had the sides switched in my head. Water pump is in passenger side, thermostat is on driver side.
Old Nov 11, 2013 | 07:57 AM
Thanks Jeeper42, we also have some kits that have the hardware like the thermostat kit above.
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
rikaro
Sep 21, 2015 06:57 AM
olson187
Sep 18, 2015 10:26 AM
mimaal
Sep 4, 2015 09:09 AM
