Mini R56 cranks but won't start
Old Oct 23, 2013 | 04:15 AM
linmaster's Avatar
linmaster
I have an issue with my Mini Cooper 2007 R56 (150k km mileage). It has had this problem a month after replacing the clutch, but it seems to get worse now. Most of the time it starts successfully but sometimes it just cranks forever and not start, I push the stop button then it shows yellow steering lock warning light with exclamation mark for few seconds and immediately shows yellow cruise control light with exclamation mark. Eventually, it would start successfully and shows yellow engine malfunction light. Sometimes it cuts while driving and shows the same warning lights.
A month ago i took it to one BMW dealer, they could not find the problem on diagnosis. So they did full service (spark plugs, oil, brake fluid, air filter). Took it to another BMW dealer a few weeks ago, they replaced themostart and some oxygen sensor, whole job for $800. The same day after getting back my car, still has both starting and cutting issue. Took it back to them the following day, they still can't diagnose the problem. The car is not storing any faults they say. And they don't think it's the fuel pump. Anyone had similar problems before? Please help guys, I reli don't know what to do now.
Old Oct 23, 2013 | 09:24 AM
AZdsrt's Avatar
AZdsrt
Guess here, but I'd bet on the fuel pump..
Old Oct 23, 2013 | 11:50 AM
dmyer's Avatar
dmyer
When the fuel pump goes you should get an engine malfunction 1/2 power - I did.
Old Oct 23, 2013 | 01:33 PM
aklucsarits's Avatar
aklucsarits
What did the dealer say the compression numbers look like?
Old Oct 24, 2013 | 01:13 AM
linmaster's Avatar
linmaster
Their technical foreman drove the car arounnd and experienced the fault as well last evening. The car still stores no error. I guess its because the problem is intermittent. Now they want to strip down and measure the wiring (on my bill).
Old Feb 24, 2014 | 05:57 PM
tim oneill's Avatar
tim oneill
Linmaster, what was the outcome? Did they find the fault?
Old Feb 25, 2014 | 03:19 AM
linmaster's Avatar
linmaster
They had to change both fuse boxes and the car was fine.....exept for the new ABS warning light. They claim the work they undertook wouldn't temper with the ABS pump (internal fault - pump needs replacement) ~ $2500.
Old Feb 25, 2014 | 04:33 PM
tim oneill's Avatar
tim oneill
My 07 has been in the shop for NINE weeks now and today they decided to replace the wiring harness but I've been saying all along that right before it stalls I hear a "click" under the drivers foot well (relay) on the fuse panel. Hopefully this nightmare will end soon.
Thanks for your reply back.
Old Aug 25, 2018 | 10:11 AM
Maki's Avatar
Maki
2009 mini hatch
Same problem Replaced R56 engine plug and play but engine wo’nt start has spark fuel and compression No one knows what the problem js could it be a faulty DNE ? Please help Joe
Old Aug 25, 2018 | 01:11 PM
actasci's Avatar
actasci
My problem was rear fuel pump. When it fails, engine will crank forever but wont start.
Old Sep 1, 2018 | 03:56 AM
MiniToBe's Avatar
MiniToBe
If you have spark and fuel why wouldn't it start unless you dont have compression!
Scan for codes. Also, make sure the crankshaft sensor is pluged, the ground starp is attached, the coil packs ground wire is attached.
Where you located?
Old Apr 22, 2024 | 02:22 PM
loxlear's Avatar
loxlear
I have the same issue. Just rebuilt the engine new head, new pistons and rings, new timing belt. Car cranks, but wont fire up. It has spark, fuel and compression. How did you solve your issue?
Old Dec 14, 2024 | 12:52 PM
outlawspeeder's Avatar
outlawspeeder
Following??
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Lt. Dan
Aug 10, 2015 12:46 PM
tippin
Aug 5, 2015 08:43 AM
