sunroof won't open
Old Sep 25, 2013 | 02:11 PM
larry728's Avatar
larry728
sunroof won't open
My 2008 cooper s has a sunroof that will not open more than a crack. the left front does not rise with the other corners. I heard a 'pop' when I was driving on two occasions. Not sure if it was related. Shop says only thing to do is replace the entire thing, roof cartridge, for about $2500. Anybody else have similar issues?
Larry in PA
Old Sep 26, 2013 | 11:34 AM
RobertJ's Avatar
RobertJ
Yes, several people have, and you should start by doing an advanced search in the forum for Sunroof in the subject. You'll find plenty of threads regarding the issue and what people have done to resolve it.
Welcome to the forum.
Old Oct 5, 2013 | 05:57 PM
afadeev's Avatar
afadeev
Larry in PA
Larry,
I had a similar issues on my '08 MCS that was traced to deformed sunroof seal. Specifically, when car was left under the sun, the sun roof would not open. At best, it would rise a bit into "vent" mode, or rise and half way before quitting. After the roof cooled down, it would start working again.
This was the last repair done under warranty, and the dealer replaced the seal part #54-10-7-210-652. Accompanying notes read: "Roof sticking and jammed as per SI 540308; removed glass, cleaned and lube complete sunroof cassette; replaced damaged perimeter seal and installed glass; adjusted to spec."
Hope this helps,
a
ToyCar
Nov 19, 2023 05:20 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
