Battery dead!
Old Apr 20, 2008 | 06:20 PM
Big K's Avatar
Big K
Battery dead!
Ok so I killed my battery today, jumped it, started up no problem, but now I have the seat belt/air bag warning icon. The book says fasten seat belts anyway and take it to the dealer. Is there anything I can do to erase this warning or is this somthing the dealer has to look at?
Old Apr 21, 2008 | 10:12 AM
djam43's Avatar
djam43
Air bag reset is strickly a dealer function. You may also need to have the charging system/ battery checked / replaced under warrenty as you should not have had a flat battery under any circumstances .
Old Apr 21, 2008 | 01:53 PM
kenatminimania's Avatar
kenatminimania
Leaving your keys in the ignition will drain the battery over time...
Old Apr 21, 2008 | 03:09 PM
djam43's Avatar
djam43
The R56 computer should shut down the drain source after a fixed time to prevent total discharge.
Old Apr 21, 2008 | 06:19 PM
Big K's Avatar
Big K
Ok let me explain a little more, I was in the process of replacing my door handles. On replacing the glass and adjusting it with the boot open and the stereo playing I drained the battery. Anyways today I called the stealer and made an appointment to have a look see, they said that the airbag sensor in the driverside door was not responding and needed to be replaced. Where the heck is the sensor and is it possible that I messed something up when disconnecting and reconnecting the wire looms in the door? So I have to go back when the part comes in. Also I'm having the windshield washer nozzles replaced due to weaping.
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
dutchhome
Sep 30, 2015 07:17 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
