Roundabout causes many warning lights. Sound like a fault?
Old Jun 22, 2008 | 07:31 AM
wolfe's Avatar
wolfe
Had this happen twice yesterday. It was quite a mess, but here's the order as memory serves:
While making a few laps of a roundabout at moderate speed, the following happened:
BRAKE was illuminated in red, the orange ! triangle with circular arrow around it was also lit. The tach center display first showed the orange triangle symbol, then changed to a ((!)) symbol which turned from orange to red and remained red. all three of these stayed on until the car was parked (first time it happened) or exited the roundabout and drove for a couple of hundred feet.
DSC was on the first time, and off the second time. Sport mode was also engaged the second time.
Looking in the manual at the warning light section, there's nothing listed for this combination. All similar combinations said 'vehicle electronics failure'.
The SZL module has already been replaced several months ago. It's an '07 Cooper S with automatic transmission, and the brake fluid level looked good.
Anything I can check for, or is it a job for the dealer? Also, should it have stored the codes even though there's no lights on now?
Thanks for any help.
Old Jun 22, 2008 | 07:38 AM
korby's Avatar
korby
I've had this happen when going on a twisty freeway on ramp , but the lights went off by themselves . It was very distracting while taking a quick corner .
Old Jun 22, 2008 | 08:39 AM
Spice Orange JCW's Avatar
Spice Orange JCW
I am not familiar with a Mini yet, But on other cars that would sound like the brake fluid is low.
Old Jun 22, 2008 | 09:07 AM
Big Daddy's Avatar
Big Daddy
Check the sensor cables to your front wheels. My wiring harness in the front left wheel came loose once while doing a sharp left-hand turn and ABS, TPMS, DSC and Brake warning lights all came on. That might be the issue. Good luck.
Old Jun 22, 2008 | 03:33 PM
sk8erguyzach's Avatar
sk8erguyzach
the flat tire indicator comes on when u take a turn at a high speed dont no about the other lights this happened in my 03 so dont no if its an issue to newer models good luck with the problem
Old Jun 22, 2008 | 06:34 PM
jggimi's Avatar
jggimi
When brake fluid is not completely full, you can get odd combinations of warning lights which are not articulated in the manual.
Save yourself a trip to the dealer, and check the fluid level. If it is midway between full and low, fill it.
Take it from someone who wasted a day at the dealer.
Old Jul 2, 2008 | 01:28 PM
wolfe's Avatar
wolfe
Thanks for this, that seems to be exactly what it was. It was about halfway between the marks, so I topped it up to full. Did a few laps of a roundabout and no lights came on.
Inziladun
Sep 3, 2015 10:35 AM
bcman
Aug 28, 2015 04:47 PM
Aug 24, 2015 02:47 PM
JamJam43087
Aug 16, 2015 02:02 PM
