Anyone with coolant that looks like this?
Old Jul 10, 2012 | 09:17 PM
gibaholic's Avatar
gibaholic
Dealer says it is fine. The was 3 days old BMW blue coolant after driving about 50 miles.
Old Jul 11, 2012 | 03:40 AM
countryboyshane's Avatar
countryboyshane
Those brown floaters are kinda gross.
How old was the previous coolant?
Old Jul 11, 2012 | 04:17 AM
tominizer's Avatar
tominizer
Wonder if the brown floaters are oil?
Old Jul 11, 2012 | 06:13 AM
mini4mo's Avatar
mini4mo
That was might first thought.
So "blue coolant" was added to green coolant?
Anyway the coolant does look kinda dirty or mixed.
Old Jul 11, 2012 | 07:36 AM
Braminator's Avatar
Braminator
Yes that is oil. Did you flush the system before adding the new coolant?
Old Jul 11, 2012 | 08:04 AM
gibaholic's Avatar
gibaholic
Coolant was changed by the dealer for water pump recall in 2/12. Then again on Thursday with replacement of the thermostat housing.
Old Jul 11, 2012 | 08:19 AM
Braminator's Avatar
Braminator
Unless you see more, I would not worry. Just check it evey now and then. If it gets worse, you have a problem.
Old Jul 13, 2012 | 06:01 PM
gibaholic's Avatar
gibaholic
Thanks for the replies. Sent the car back to mini for a leak down test since I can't afford to wait. I bought the car used and only have 50 miles left on the warranty they gave me.
Old Jul 14, 2012 | 06:14 AM
gregsmini's Avatar
gregsmini
My experience was that they refilled the coolant when they replaced my water pump with the recall. The coolant wasn't really changed or flushed.
Depending what they find, you might want to pay them to do a complete coolant flush, at the same time documenting with them the picture that you posted above. I agree that it certainly appears to be oil, which could indicate internal problems that existed when you bought the car.
Keep us posted on the outcome and good luck.
Old Jul 17, 2012 | 06:23 PM
gibaholic's Avatar
gibaholic
Update: coolant system pressure tested over the weekend. Passed, Did not loose pressure. However, a cylinder compression check yesterday reveled cylinder 3 was much lower than the others.
Old Jul 17, 2012 | 06:55 PM
Psquared's Avatar
Psquared
Maybe a bad head gasket causing oil to get into the cooling system?
Have you checked the oil lately? Is there any foam on your dipstick?
Old Jul 17, 2012 | 08:42 PM
gibaholic's Avatar
gibaholic
Head gasket is the likely problem. There was no water in the oil via dipstick or fill cap. The oil was about 1/8in low in 500 miles. Coolant was burning off.
Old Jul 20, 2012 | 07:47 AM
Beau M's Avatar
Beau M
Most importantly... is the dealer fixing it under warranty?
Old Jul 20, 2012 | 10:26 PM
gibaholic's Avatar
gibaholic
Dealer is going to buy it back....... now I have to find another one. Errr
Old Jul 21, 2012 | 06:23 AM
Braminator's Avatar
Braminator
What did they find since they want to buy it back?
Old Jul 22, 2012 | 08:33 PM
gibaholic's Avatar
gibaholic
it was non mini dealer. They freaked when they got the quote from a mini dealer for to fix it.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
