Mini Cooper key wont start car.
Old Aug 5, 2012 | 10:58 AM
Michael Ravellette's Avatar
Michael Ravellette
Ok heres the deal, I have a 2007 Mini S with out comfort access. The Key Fob will unlock the doors and roll down the windows, when i put it in the key slot to start the car it does not recognize that its there. it does not go into ACC mode and the car will not start. The radio works like normal when the cars completely off like it should, which means the battery is not dead. Please any help would be great.
Old Aug 5, 2012 | 11:20 AM
rkw's Avatar
rkw
What's the history behind this? Did it work before and stopped working? Do you have another key that does work? The battery may not be "dead", but you should still check the voltage.
Old Aug 5, 2012 | 11:38 AM
Michael Ravellette
how it started
Well i started having trouble getting it to recognize the key a couple days ago but it was intermittent. Finally yesterday it just stopped. If it was the battery it should still recognize the fact of putting the key in then give me the low battery symbol. I only have one key. I feel like its either the key or the receiver. looking for someone who has seen this problem in particular and found the solution.
Old Aug 5, 2012 | 11:54 AM
InTheClub's Avatar
InTheClub
I'd get the battery checked out just in case. I've read on here where lights, etc. still worked, but the car wouldn't crank and it turned out to be the battery. Just a thought.
You could disconnect the battery to "reset" the system & see if that helps.
BTW, to lock/unlock the car, the key only needs to transmit data to the car. To start the car, the key needs to have a two-way "conversation" with the car so it has to receive data as well as transmit data. Your key might not be receiving data correctly...
I found this info from this thread located at https://www.northamericanmotoring.co...y-fob-fix.html
Maybe that thread could help as well. Good luck!
Old Aug 5, 2012 | 12:10 PM
chick draper's Avatar
chick draper
You can read my tale of woe here:
https://www.northamericanmotoring.co...-new-mini.html
I sincerely hope yours turns out nothing like mine. I don't know if it will help you, but mine started exactly the same way and, as far as I'm concerned, they haven't actually solved the initial problem yet.
Best of luck to you!
Old Aug 5, 2012 | 01:07 PM
AustinS's Avatar
AustinS
THIS...is why I would much rather have a "key" instead of a fob.
Old Aug 5, 2012 | 01:12 PM
bmwr606's Avatar
bmwr606
i have heard of this happening on a bunch of 2012s, turned out to be a loose connector at the key slot in the dash
fix is to push the connector on until it "snaps" in place
scott
Old Aug 5, 2012 | 02:11 PM
Michael Ravellette
scott ill try the quick fix first but i bet its the Key Fob like what happened to chick Draper. lucky for me my chains already been replaced. I do a lot of my own work most of the time but cant do the electrical stuff.
Old Aug 6, 2012 | 02:12 PM
Michael Ravellette
ordered a new key today, lets hope thats the problem. the key reader at the dealership couldn't even read my key so i'm pretty sure thats the problem.
Old Aug 22, 2012 | 04:21 PM
Michael Ravellette
Got the new key, It works. Thank god. there is the fix to this problem.
Old Jun 21, 2013 | 12:24 PM
vulcanram's Avatar
vulcanram
2009 ClubmanS
Wife's key fob started acting up yesterday and she got it to work couple times enough to get her back to work. My key works fine. We've swapped keys and I can't get hers to work at all. It feels like it's not seating correctly in the slot, although it does fit but just doesnt feel "normal". It will lock and unlock, however I haven't tried the windows. But none of the electronics (lights, radio,etc) work when seated...so I figure the windows wont work either. HELP!
Old Jun 21, 2013 | 01:01 PM
chick draper
Do yourself a favor and call MINI of Dallas and talk to Tony in Service. He is a Tech there and will take good care of you!
Edited:
Oh, actually, I just realized you may not be in the Dallas area. Sorry. As for me, the initial problem that I had was solved by replacing the key fob. I also wish there was a regular key and much less electronic control of all the components in the car.
Good Luck!
Old Jun 21, 2013 | 01:57 PM
MikewithaMini's Avatar
MikewithaMini
Good Luck!
Tony is actually not a MOD anymore. He manages a shop in Arlington called
I AUTOWORK
1075 DUNCAN PERRY RD. SUITE 1-101
ARLINGTON T.X 76011
Phone 469-563-2550
Board Name (sk8terboy)
Contact for appointment, SPECIAL LABOR RATE FOR MM.ORG MEMBER
He's good and has taken care of me! I wish he were closer.
Old Jun 21, 2013 | 05:34 PM
Studhilo's Avatar
Studhilo
This doesn't answer the specific issue, but might solve the puzzle for someone else. I had never used the 2nd key that came with my new Mini. Several months after I bought the car, I thought I'd use it, as I had been told the battery needed a charge now and again. The key didn't work, would not start the car. I took it back t the dealer and it turned out they gave me the key to another car that they had sold. They ordered me a new keyfob.
Old Feb 3, 2016 | 12:07 PM
My2-CooperS's Avatar
My2-CooperS
07 mini cooper S will not intialized its remote and starting the motor
I was wondering you got any answer to your posted.
I had Mini cooper S, will not initialzed the key 07 mini cooper S
Help, somebody!
Im in trouble gettting my cooper S intialized its remote and starting its motor. There were suggestions online i had tried them. Seems no help. Bring battery to autoparts to tested, says good..now im ran out of thoughts what to do.
Appreciated if anyone been through this before or suggestion. I would greatly like try and thanks for sharing the experience.
Gary
Old May 29, 2016 | 01:39 PM
aliciasosa8's Avatar
aliciasosa8
Same Issue!
scott
Hi - I'm having the same issue! But when I took my car to Mini service to order a new key fob, they told me that the key wasn't the issue. Do you have a 'how-to' on this fix?
Old May 30, 2016 | 07:35 AM
bmwr606's Avatar
bmwr606
i do not have a how-to, i only read about this problem here on NAM a couple years ago
Old Aug 29, 2016 | 01:29 AM
Lasttoy's Avatar
Lasttoy
my key works everything, but will not start car, weird, installed new trans yesterday, last night would not start, lights windows work perfect??
i will try other fob when ssun comes up
Old Mar 18, 2019 | 06:23 PM
Eli dirtyboy Perez's Avatar
Eli dirtyboy Perez
Have same problem exactly the same
Did you fix it ?? And what was wrong ?? Mine does the same radio works ,unlocks and locks high beams work but not the headlights
Old Jul 2, 2019 | 04:52 AM
Corky Toole's Avatar
Corky Toole
Key fob won’t start car
2008 Mini Cooper s .. key fob does everything but turn the car on, UNLESS, the fob is in the ignition.
Is there a receiver problem, fuse, ... ?
Old Mar 5, 2023 | 03:44 PM
sashar7777's Avatar
sashar7777
I had this problem with my 2011 Mini Cooper. The issue turned out to be a bad key fob. Had a locksmith come by make a new one and all good now. Hope it helps someone.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
