Could it be a fuel pump fauilre?
Old May 8, 2017 | 03:06 PM
theateist's Avatar
theateist
I have R56 2009.
This morning when I tried to start the car, it started and then immediately died. Looks like choking. I tried a few times again, but it always starts and then dies. On a forth time I started it and it started but it started sort of to cough and eventually died. No check engine or something like this. I tried to read codes but the only thing the device showed is "Emission related engine dtcs" and then no error codes.
Could it be fuel pump? Or the fuel pump failure should have check engine light?
Old May 9, 2017 | 10:00 AM
thefarside's Avatar
thefarside
The HPFP died on my 07 S. It took several weeks of sullen staggering starts for a DTC to set that indicated the cause. DTC codes in the Mini typically won't set until some number of iterations. So no check engine light.
As far as I can tell, the primary (low pressure) fuel pump is quite reliable.
How many miles on the car? S?
Old May 9, 2017 | 04:57 PM
oldbrokenwind's Avatar
oldbrokenwind
Originally Posted by theateist
I have R56 2009.
These are the symptoms I get when a post-turbo hose is disconnected / loose --- any connection between the turbo and intake manifold, and there's a bunch of them, none are easy to access. No codes either. Good luck ---
Old May 15, 2017 | 12:25 PM
theateist's Avatar
theateist
I took it to the dealership and it was the HPFP failure. Apparently MINI extended the warranty on it for 10 years so I was covered by warranty.
