Bought a 2011 JCW with problems! Need a little advice
Hi Guys, bought a 2011 JCW R56 as it was a really really good deal I couldn't not act upon. That being said, the car has issues... as in codes upon codes. I am a fabricator for my line of work, so I am looking to fix everything myself.
I have codes -
P15DF
P0087
and 300 thru 304 (misfires)
I am pretty sure the car needs the HPFP, as it stumbles on starting and seems to run as if it is starving for fuel.
The one code I am not sure what it is -
P1869 ... Air bag code... anyone ever deal with this one? Fix?
Just want some input, as I searched I couldn't really find anything.
Thanks in advance!!!
I have codes -
P15DF
P0087
I found this with a quick and dirty google search:
http://p1869.engine-trouble-code.com/
That code could also be a result of the HPFP, but could also relate to a bad MAP sensor.
If it were me, I would change out the HPFP and clear the codes. Then, run the car to see if any of the other ones show up, and go from there.
I would throw a set of plugs in it. They are supposed to be changed every 30k miles on a JCW. That way you have an excuse to look at the coils at the same time. Even if the codes are hpfp, it won't hurt.
Mike
Mike
I think, mid way through 2011 prod year they stopped using the N14.
I have codes -
P15DF
P0087
I have codes -
P15DF
P0087
