Rear Main Seal Failure
Old Nov 24, 2007 | 04:46 AM
Duffer's Avatar
Duffer
I took my Cooper in to resolve an oil leak and they had to drop the transmission and replace the rear main seal in the engine. According to the Service Mgr this is the 1st one they've seen on the 2007.
Old Nov 24, 2007 | 05:48 AM
R56 Ed's Avatar
R56 Ed
Sorry to hear about the problem, but glad it's a warranty issue. How many miles on your car before the symptoms began? Anything unusual like strange noises/vibrations?
My dealer had to replace my 6 spd tranny at 200 miles. The new one has almost 5k on it and is working perfectly.
Thanks, and good luck!
Old Nov 24, 2007 | 04:32 PM
dneal's Avatar
dneal
Have you or anyone else added or changed the oil? Most rear main failures are from too much oil... :/
That being said, it's also entirely possible the seal was faulty or installed incorrectly at the factory.
Old Nov 24, 2007 | 06:09 PM
Duffer's Avatar
Duffer
I noticed it while having an break in oil change done at 1800 miles. There were no other indications of the problem.
Old Nov 24, 2007 | 06:36 PM
Duffer's Avatar
Duffer
No, the leak was noticed during its first oil change.
Old Nov 25, 2007 | 07:48 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
I recieved my MCS on May 19th......it was back at the dealer two weeks later to have the rear main seal replaced. at first I thought it was cosmoline melting off the engine.
after the seal was replaced is when all the fun started. I began to have all sorts of transmission problems after that.
Old Nov 26, 2007 | 03:28 AM
Duffer's Avatar
Duffer
What type of problems?
Old Nov 26, 2007 | 04:24 PM
Xray'dit_Mini
the first problem was a loud knock from the trans at idle in neutral. they first replaced the fly wheel, then the clutch and throw out bearing, and finally the whole tranny. About 800 miles later the famous 3 - 2 squeal reared it's ugly head. Thats where you shift from 3rd to 2nd and it lets out a banshee howl.
Old Nov 26, 2007 | 08:53 PM
Noegel's Avatar
Noegel
Ugh, I hate those damn banshees.
Old Nov 27, 2007 | 02:13 AM
Carey934's Avatar
Carey934
I have had my rear main seal replaced when the car had 10,000 miles on it, and now it needs it again with 22,000 miles on it. This is a standard 2005 Mini, no-s, not convertible. I'm sorry I bought it.
Old Nov 27, 2007 | 09:20 AM
daffodildeb's Avatar
daffodildeb
Carey, you're in a '07+ thread...
Old Nov 28, 2007 | 05:34 AM
scottab36's Avatar
scottab36
I have also heard this banshee howl. It only seems to appear when I let out the clutch too slow at too high of an RPM. I have adjusted my shifting to eliminate this noise. Let me know if yours is the same please.
Old Nov 28, 2007 | 07:12 PM
Xray'dit_Mini
I found that I shift better when in sport mode, so that is what I drive in 100% of the time. I rarely hear the noise now.
Old Nov 28, 2007 | 08:54 PM
daffodildeb
Ditto. (I've never had the noise, though.)
Old Jan 11, 2013 | 02:30 PM
minipb's Avatar
minipb
Main rear seal
Can anyone give me a ballpark of cost for fixing a leaking rear main seal? Should I have the clutch replaced at the same time? Car has 44,444 miles on it. Clutch seems fine.
Old Jan 11, 2013 | 02:59 PM
countryboyshane's Avatar
countryboyshane
Might as well replace that, the fork, pivot, throwout bearing, and guide tube while it's all apart. That's a lot of labor to take the transmission off!
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Lex2008
Aug 16, 2015 08:33 PM
