Strange Problem couldn't find related thread
Old Apr 3, 2008 | 11:38 AM
Gabe33's Avatar
Gabe33
I'm not sure exactly what circumstances it takes to make it happen, but when I push my car hard, to say 110 mph, momentarily after I slow down my car is filled with a rotten egg smell. The stench only lasts for about a minute, but it makes me very hesitant to drive my car fast because I don't know what that smell is. For all I know something under the hood is melting. I already have a trip to the dealer set up in about 20 days. Should I bring this issue up, or is it just a normal thing that happens and goes away?
Old Apr 3, 2008 | 11:46 AM
djam43's Avatar
djam43
Driving your car that Fast, maybe you should check your underware.
Old Apr 3, 2008 | 12:04 PM
chiliredr56's Avatar
chiliredr56
Catalyst convertor will make that smell after hard driving .
Old Apr 3, 2008 | 12:12 PM
misslindsey's Avatar
misslindsey
Cat shouldn't make that smell, ever, and it should never get in the passenger compartment. Have the dealer check for exhaust leaks when you do your service.
Old Apr 3, 2008 | 12:16 PM
glangford's Avatar
glangford
Rotten egg smell is usually associated with sulfur. Sulfur does compete with oxygen for active sites on the catalytic converter. That is why some PZEV vehicles recommend BP or low sulfur fuel, and why CA is all low sulfur fuel. My guess is at that speed (and resultant exhaust flow rate) the catalytic converter will get quite hot. Under those conditions it may be expelling larger amounts of sulfur compounds than under normal conditions.
I have gotten rotten egg smell out of my Honda Accord, and I know that to be the reason. Many cars will have a slight sulfur smell. This smell will eventually decrease with age of the car and break in of the catalytic converter. It has in my accord. Emissions is fine.
The smell will usually be worst on cold start up, or hard acceleration. Sulfur amounts vary state to state, but you could try BP. Another thing to try would be to not drive 110 mph.
Old Apr 3, 2008 | 12:21 PM
chiliredr56
Well put glangford . I did not have time to go into detail as you did . I have worked in the service department for dealerships for 31 years . I see this very thing everyday from cats . Normal .
Old Apr 3, 2008 | 12:25 PM
glangford's Avatar
glangford
Read your post again. The momentarily after slowing down from 110 mph is a strong indication of a hot catalytic converter and the catalyst dumping excess sulfur. If your window is down you probably can smell it. It takes very little sulfur to actually smell, if you've ever lived near a paper mill and smelled thionyl chloride, you'd know. Shouldn't be a concern, other than perhaps driving habits. If your windows are up when you slow down, then I would take the previous recommendation and look for exhaust leaks into the cabin. There sulfur is not the problem, but odorless carbon monoxide.
Old Apr 3, 2008 | 12:43 PM
Arnbut's Avatar
Arnbut
Some of my Ford 4.6L's did the rotten egg cat smell when the valve stem seals were worn and oil was getting past too...
Has anybody else gotten the burnt cat (not cat-con; I mean kitty-cat) smell after a hard run at altitudes over 3000 feet? I get it on an easy run at very high (over 9000 feet) and harder runs at lower elevation. Dealer can't duplicate, of course...
Old Apr 3, 2008 | 02:00 PM
Gabe33's Avatar
Gabe33
Thanks for all the help guys. The only times that I have smelt it were when my sunroof was cracked open so it must be the catalytic then. It's quite the relief knowing that it's not some terrible malfunction happening in my car.
Old Apr 3, 2008 | 02:03 PM
MGCMAN's Avatar
MGCMAN
Gabe,
No more egg salad sandwiches for you.
Sounds like the Cat has a little too much unburned fuel in it when you abruptly lift the throttle at speed.
Old Apr 11, 2008 | 08:06 AM
Swucker_Barnhue's Avatar
Swucker_Barnhue
Same Issue Here
I have smelled this as well from my 2007 MCS. Unfortunately, not after going 110. I notice it sometimes after rapid acceleration / deceleration when in town. Hard driving always precedes the stench.
Old Apr 11, 2008 | 12:34 PM
Bigjoeski08's Avatar
Bigjoeski08
I have also had this smell after going up and over 100mph. But goes away within 20 seconds, I feel better I thought it was my clutch burning somehow.
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
bc219
Aug 10, 2015 11:22 AM
Lt. Dan
Aug 10, 2015 08:23 AM
