High pitch whine
Old Mar 21, 2008 | 07:07 PM
BrandonH's Avatar
BrandonH
High pitch whine
This noise has to be coming from the turbo. I was down shifting from 4th to third through a 65deg turn and the most horrible whine happened under the hood (sounded just like a grinder warming up). This is my first turbo ed car i have owned but i have driven plenty. I have never heard of this sort of thing happening when you do either engine braking or even high rev matching. Has anyone done any spirited driving and have heard this or s it localized to my cooper?
Old Mar 22, 2008 | 03:23 PM
edijak's Avatar
edijak
Synchronize RPM
I have heard the same thing and I find that it happens when down shifting without getting the revs up to match. Try jumping on it a little, throw the clutch in without reving up during the downshift and delay release of the clutch. My bet is you will hear the whine. If not that then , I know not what it may be.
Old Mar 23, 2008 | 09:54 AM
BrandonH's Avatar
BrandonH
I will give it a shot, but i am really not trying to duplicate the noise i just want to know if it was normal. If other people have heard it and its not just me then ......... i am not crazy. It really sounds like i still haven't mastered driving my car yet. Thanks for the response.
Old Mar 23, 2008 | 09:58 AM
Guest's Avatar
Guest
Haven't heard a noise like the one you describe, but you shouldn't be hearing any type of grinding noises from the turbo . If you downshift by dropping the clutch in to the lower gear, then yes you'll probably hear quite a few bizarre noises, you need to rev-match the gears before downshifting.
Old Mar 23, 2008 | 05:27 PM
ANT818's Avatar
ANT818
Rustyboy,
That must be some chunk of change you invested into you Mini.
Old Mar 25, 2008 | 09:44 AM
pyskacz's Avatar
pyskacz
I heard that noise once myself, although I was cruising at a sporty rate of speed and downshifted into second and braked at the same time, because I got cut off. I didn't have time to rev up to match....
Old Mar 26, 2008 | 07:57 AM
djam43's Avatar
djam43
Sounds like my ex wife.
lweaver
Sep 17, 2024 08:22 AM
Casrio
Apr 20, 2021 01:52 AM
Camaro108
Sep 9, 2015 04:37 PM
Camaro108
Sep 9, 2015 01:56 PM
