new mini
new mini
New 2008 base mini picked up today. 4 miles on the odometer.
Two questions:
1. Turning the headlamp stalk to "on" position doesn't seem to do anything - the headlamps (not fog lamps) seem to always be on. Is this normal or adjustable?
2. The driver's side mirror motor seems "quirky" - seems like it grinds and then catches and doesn't seem to travel or adjust to "higher" viewing range (as if you were trying to see up into SUVs behind you). Is that abnormal? I suspect so just because the passenger mirror seems to have very good adjustment range.
Thanks.
Greg
Two questions:
Thanks.
Greg
Why are you messing about here. Take it back to the dealer
Before signing any papers, I check everything out. I run/operate EVERY control. I run it on a highway and in stop and go traffic making sure it has reached operating temperature. The radio is always off, unless its being checked.
If you've ordered it make sure all fluids are topped off. You'd be surprised at some of the horror stories. You've invested lots of time waiting around. Don't leave anything to chance.
I only got burned once. It was late at night and it was cold. I didn't check the AC. Turns out the AC needed freon. It only cost me some time dropping off and picking up the Jeep. But, it was my fault for not checking.
A few minutes spent up front will result in saved hours/days later on.
ok so far
Two questions:
Thanks.
Greg
Two questions:
Thanks.
Greg
Dec 23, 2015 10:36 AM
Aug 7, 2015 05:55 AM
