Tensioner 11-31-7-607-551
Old Mar 12, 2011 | 05:30 PM
jacknk's Avatar
jacknk
I purchased a tensioner putting my engine back together and this is the one I bought. Does anyone know if they have had this tensioner put in their car and if so what were the circumstances. I have not seen this number mentioned by anyone. Thanks.
Old Mar 12, 2011 | 05:53 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
It the newer longer tensioner. 11-31-7-607-551
Usually not used when replacing the entire chain and tensioner parts for the R56 "death rattle".
Old Mar 12, 2011 | 07:27 PM
jacknk's Avatar
jacknk
Thanks for the answer. The problem I have is that no one seems to be able to tell you what to use. I think I going with the above tensioner, my old sprockets and chain and new guide rails. Hope it works.
Old Mar 12, 2011 | 10:26 PM
joey1320's Avatar
joey1320
The new 551 tensioner is longer and will make-up the slack by a stretched chain, but a chain not over the limit -- 68mm when using the BMW special tool.
You have to remove the tensioner and inspect the limits of the chain, based on your findings you either replace the tensioner with #551 and if it's over the limit, you replace the whole thing with tensioner #895.
Old Mar 12, 2011 | 10:37 PM
joey1320's Avatar
joey1320
Quick question, how do you plan on locking the crank and cams in place?
vulkandino
Oct 31, 2015 08:29 PM
pahg
Oct 5, 2015 11:50 AM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
donniedarko
Sep 29, 2015 01:16 PM
