Weird Noise (Need Help)
Old Sep 23, 2018 | 05:41 PM
JayyFerrer's Avatar
JayyFerrer
So this noise has been occurring when I accelerate. It happens at every gear. I just flushed the transmission fluid and replaced it but this was going on even before that.
Old Sep 24, 2018 | 06:55 AM
MiniToBe's Avatar
MiniToBe
remove the valve cover and take a look....usually with weird noises, it isnt a good idea to over rev the engine. you might make the issue even worse let's see if the chain was slapping around or the timing rail is cracked.
also check the oil level.
welcome aboard
Old Sep 24, 2018 | 03:28 PM
cargusjoh's Avatar
cargusjoh
Hard to tell. If it is the belt end of the motor can be timing chain. We had similar noise on the belt side, sounded terrible, and it was a completely worn out alternator bearing. Bottom line I don't know, but offer you support on your journey.
Old Oct 1, 2018 | 08:03 PM
JayyFerrer's Avatar
JayyFerrer
I replaced the timing chain and tensioner as well as the belt. I think it might have something to do with the clutch because I did all this, and the noise goes away as soon as I press the clutch in.
Old Oct 2, 2018 | 10:23 AM
Yupetc's Avatar
Yupetc
Check the throw out bearing on that clutch. I've had similar issue with another car before, but it sounded similar.
Pete
clammy77
Jun 28, 2016 07:25 PM
whosurgaddy
Aug 29, 2015 09:50 AM
mariano
Sep 10, 2011 06:27 AM
jcarlos914
Oct 2, 2010 11:05 AM
m_bisco
Jun 23, 2010 07:24 PM
