Paddle Shifter Problem
Old Jan 3, 2018 | 07:00 AM
Neal3000's Avatar
Neal3000
When i try to use my paddle shifters it up-shifts fine but won't down shift at all. Anyone have any ideas on what the problem might be?
Old Jan 7, 2018 | 07:49 PM
Neal3000's Avatar
Neal3000
Anyone?
Old Jan 7, 2018 | 08:53 PM
FlyByMike's Avatar
FlyByMike
No concrete ideas. Does it downshift with the shift lever ? Are you in Manual Sport mode ? Left and right paddle won't down but will up shift ?
-Mike
Old Jan 8, 2018 | 06:41 AM
Neal3000's Avatar
Neal3000
Yes it will downshift with the stick
In sport mode yes, it will upshift with the paddle shifters but no down
Old Jan 8, 2018 | 04:15 PM
FlyByMike's Avatar
FlyByMike
If you're up to it, perhaps you can figure it out by digging through here: https://www.newtis.info/tisv2/a/en/r56-cooper-s-hat/. I never looked it up for my R56 but did so for my F56; not an easy task so persevere.
My guess is a loose connector/pin somewhere between the steering wheel and the BDC computer. Or the BDC is went bad.
-Mike
Old Jan 9, 2018 | 08:18 AM
Bnourai's Avatar
Bnourai
First thing I would do is to open the column and check for the connector to the left shifter. If it has come loose it's easy just press it back, I did this on my 370z and now it works like a charm. If the BDC was no good I do not think your up shift would work.
Ben
JohnTurbo
Apr 12, 2020 09:09 AM
kpflynn
Oct 14, 2009 04:52 AM
Eddie@1FastMINI
Jan 26, 2009 12:15 PM
MrV
Aug 20, 2006 07:41 PM
Lazy Vulture
May 1, 2005 09:55 AM
