hello everyone new clubman s..well "wife" is owner lol
im having issues already..sigh. #3 misfire..only code. put new injector/coil/plugs/camshaft sensors/sea foam/pulled and cleaned all wiring/traced injector and coil wires no breaks/checked for vacuum leaks on the couple of lines..NO JOY! pulled injector rack again..checked all..all good. what about that sensor at bottom of the rack or the vanos? i did pull and clean the vanos also. getting frustrated but sticking to it..car ran awesome till just started flaking out 1 morning and wife faction is dropping fast..grin. any help is appreciated. 2011 mini clubman s..new turbo btw.
Can you scan for codes, do you have a schwaben scan tool? I would get those codes first after you clear them from all the repairs and see what comes up.
https://www.northamericanmotoring.co...d-q-and-a.html
i did and all i get is a p303 misfire. replaced injector/cam sensors/crank sensor/knock sensor/plugs/coil and still nada. im in a bind cause i need to return to work and 1 vehicle doesnt cut it :( any help you can give
All I can think of is check the wiring harness, maybe something got bumped or cut on the wire harness when you did the turbo or any other work?
