Engine vibration upon moderate acceleration.
Old Jan 9, 2018 | 04:46 PM
Jordan Frizzell's Avatar
Jordan Frizzell
So I have 2007 MCS N14 and I recently noticed a vibration in my front end when accelerating in 3rd and 4th gears and occasionally in 2nd and 5th. My suspicion is the motor mounts because the engine vibrates pretty heavily when at a stop light or idling. I have not noticed the engine itself shifting back and forth when I rev it either. I’ve also suspected the drive axles. I don’t hear any drive axle noises at this point so I’m not sure what to think. I don’t see any visible CV joint leaks although I know they don’t always show signs that they’re bad. Just to add I have recently installed lowering coilovers, front sway bar stabilizer links and adjustable rear lower control arms. I had the alignment done and it handles just fine. My ball joints are in good shape.
If anyone can help that would be great before I go dumping money into new drive axles!
Old Jan 12, 2018 | 01:21 PM
MiniToBe's Avatar
MiniToBe
sometimes the engine/transmission mount nut gets loose. double check that one.
cooperjunkie
Mar 28, 2017 10:03 PM
SooperCoopers
Oct 18, 2015 07:36 AM
venturaexit
Jun 24, 2015 11:00 AM
cabbazio311
Sep 12, 2014 06:01 AM
boognish
Aug 17, 2009 07:57 AM
