Replacing oil housing gasket on base r56 (no turbo)
Old Jan 11, 2018 | 06:52 AM
Derrick A. Lundberg's Avatar
Derrick A. Lundberg
Hello, all! I've had my mini for about a year and a half, sitting at 89,000 miles. I've had some issues with losing a significant amount of oil, however it's a quart about every 1200 miles, which falls under the range of normal for an engine not properly broken in.
I brought it to the dealer for my first oil change at about 50000 miles. I've since decided I would rather do my own work whenever possible.
I had them do a check over, and they determined I should replace my oil housing gaskets, however I have never seen visible drips under my car so my step-dad (professional mechanic, specializing in American vehicles) suggested that it wasn't worth the $950 they wanted to charge me.
With my last oil change, I did some snooping around and am convinced that there is likely a very slow leak dripping oil down the front of the engine, to the oil pan... So I would like to start planning the replacement of the gasket in the spring.
https://www.northamericanmotoring.com/forums/how-to/260258-oil-cooler-filter-housing-gasket-replacement.html
I found this tutorial on changing it for the r56s model, but I can't find any videos or tutorials for changing out the housing gasket without taking off the whole front end. This seems superfluous, from what I can tell. How might this job differ without having to deal with the turbo?
Thank you, in advance, for any advice or tips sent my way
Old Jan 12, 2018 | 09:07 PM
renchjeep's Avatar
renchjeep
On my wife's 2013 Justa, it looks like a much easier job than on my 2011 S model. Way less stuff in the way. But, if I were you, I would invest in a Bentley repair manual, especially if you plan on keeping the MINI for a while.
Whyismyhaironfire
Apr 15, 2018 07:37 AM
RexNTX
May 10, 2017 06:05 AM
girubato1
Jan 26, 2015 09:48 AM
CobraBob
Apr 21, 2014 06:59 AM
DTSJR
Jan 31, 2011 03:37 PM
