misfire
Old Dec 1, 2017 | 07:10 PM
stormreaper's Avatar
stormreaper
misfire
2011 mini clubman s misfire on 3. replaced cam sensors/plugs/coil/injector and still no fire to 3. 180 pounds compression. just stopped firing one morning and cant seem to find the problem
Old Dec 2, 2017 | 03:58 AM
MiniToBe's Avatar
MiniToBe
check electrical signals going to the coil pack and fuel injector.
Old Dec 2, 2017 | 02:59 PM
stormreaper
checked them..no breaks in either..getting signal to injector during cycle..new injector. getting fire to coil through test light and voltage meter. still no joy. moved things around and all parts work on other cylinders. stripped all wiring out and cleaned and reconnected still no joy
Old Dec 2, 2017 | 03:54 PM
MiniToBe's Avatar
MiniToBe
What is the compression on other cyls?
Old Dec 2, 2017 | 04:26 PM
stormreaper
same area. engine is tight. wondering if i should pull head and check #3 valves?
Old Dec 2, 2017 | 04:49 PM
MiniToBe's Avatar
MiniToBe
Humm...if compression, fuel amd spark all is good, then double check the timing to rule it out. If that checks, then either knock sensor or ECU is faulty.
Old Dec 2, 2017 | 08:49 PM
stormreaper
ill hit it with timing gun tomorrow. and ill check knock senscrossong fingers on ecu..thanks
tsteinmetz53
Feb 16, 2010 03:54 PM
91Eunos
Jul 18, 2008 09:24 AM
OctaneGuy
Aug 24, 2007 11:28 PM
GD-Mini
Jul 14, 2005 05:52 PM
