Wifes R55 p0300 code cyl 2 & 4?
Old Oct 16, 2017 | 11:15 AM
CamaroMan's Avatar
CamaroMan
Getting random misfires.. Do minis have shared or single coils? Maybe wasted spark?
where could I start?
Old Oct 16, 2017 | 08:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
300 is for random misfire and doesn't identify a particular cylinder.
If you have an individual cylinder misfire then you can swap the plugs and coils around to see if it moves.
But not a bad start to do plugs
https://www.waymotorworks.com/spark-...-cooper-s.html
If you need coils only go with the OEM as they will put out the actual correct spark, aftermarket usually put out less and sometimes don't fit
https://www.waymotorworks.com/direct...9-r60-r61.html
