Road Trip...Limped Home...
Old Oct 21, 2018 | 03:43 PM
httr1016's Avatar
httr1016
I purchased an 08 Mini Cooper S about 3 weeks ago. I had a PPI done and just got the car out of the shop last week to address the known oil leaks. Took the car out for her first major road trip (10 hrs to Michigan) and after 3 hours into the drive, some were in PA, on a steep uphill highway, the check engine light came on, car lost engine power rapidly despite downshifting, and I had to limp it to the shoulder. After shutting down the engine and letting it rest for about 10 mins, engine turned back on without problem, but now had a noticeable rough idle (shudder), seemed to have decreased power in 1st, 2nd, and 3rd gear, very difficult to find engagement point in 1st gear, and noticeable shudder when going through 1st through 3rd gear. Also, putting the engine under load in 1st through 3rd gears (over 2500 RPM) would make the check engine light blink, and tach needle appeared slightly erratic.
Was able to limp it back home because I was in the middle of nowhere (probably not the best for the car, but had to make a decision) and dropped it off at my normal Mini shop. I'm sure they'll diagnose pretty quick, but I'd love to hear what the community thinks is the issue.
This is my first Mini, so I'm learning as I go.
Thanks!
Old Oct 21, 2018 | 06:13 PM
AZdsrt's Avatar
AZdsrt
Without knowing what code threw the CEL, is anybodies guess.
Old Oct 24, 2018 | 03:44 PM
Wowak's Avatar
Wowak
I just had very similar symptoms with my 2010 r56 N14 Cooper S. My OBD2 reader won't talk to a Mini so I'm waiting until a local SCCA member with a BMW code scanner can help me on Friday.
Old Oct 24, 2018 | 04:03 PM
MrGrumpy's Avatar
MrGrumpy
If it was shuddering and the CEL was flashing, I’m going to guess that you were having a misfire event. As to why, well....There is no way to know without getting the codes. Sounds like it’s getting looked at, so I wish you luck, and please post what you find out.
Old Oct 24, 2018 | 04:11 PM
Wowak's Avatar
Wowak
I tried unplugging the coils one at a time to rule out a failed coil, but each one made it worse, so if the problem is a coil it's only a partial failure, if that's possible.
MrBlah
Nov 7, 2016 12:11 PM
AprilWhine
May 4, 2009 08:01 PM
yellowbritishrocket
Oct 9, 2008 10:47 AM
danjmcs
Jun 19, 2005 07:45 PM
