hose dilemma
Old Dec 26, 2018 | 07:10 AM
kucils69's Avatar
kucils69
Old Dec 26, 2018 | 08:04 AM
techman1's Avatar
techman1
Mark,
You are correct, that does not look correct. Just to confirm, what vehicle / engine is this for?
Old Dec 26, 2018 | 08:11 AM
kucils69's Avatar
kucils69
Old Dec 26, 2018 | 08:12 AM
kucils69's Avatar
kucils69
Old Dec 26, 2018 | 08:32 AM
techman1's Avatar
techman1
If it was a secondary air hose for the idle circuit, yes.
Since this is a water hose, I do not think it would affect the idle. Is there any warning light on the display?
Old Dec 26, 2018 | 08:34 AM
kucils69's Avatar
kucils69
Old Dec 26, 2018 | 09:20 AM
I like mini clubman's's Avatar
That doesnt appear to be under your intake. That looks like the turbo air feed line. That also doesn't look like a MINI hose clamp. They use spring clamps everywhere I think. For the small stuff anyways. If it's going to the thermostat then you should straighten that out.what engine do you have?
Old Dec 26, 2018 | 09:23 AM
kucils69's Avatar
kucils69
Old Dec 26, 2018 | 10:00 AM
iwashmycar's Avatar
iwashmycar
Does look like one of the many hoses that comes out of the cooling distribution thing that gets fed off the water pump tube. Cant really tell which though without a slightly zoomed out shot
Old Dec 26, 2018 | 10:31 AM
oldbrokenwind's Avatar
oldbrokenwind
First pic seems to be a hose just above the tranny linkage. That would be a heater hose from the t'stat housing to the firewall. Judging by the aftermarket hose clamp, someone did a bad job of repairing / replacing this hose. So Mark, how about a little history on this car --- how long have you had it? What were the last few repairs and who did them, an indie shop, a mini dealer, you, a mechanically-minded friend?
As mentioned by iwashmycar, a pic or description of where this hose actually connects would be helpful.
And, no, it shouldn't cause stalling, but as fussy as these ECU's are, who knows for sure.
jimmwaller
Jan 16, 2022 09:01 PM
aznqtboy984
Nov 20, 2012 06:34 AM
WoodyWold
Jan 24, 2012 06:23 PM
martinbs
R55 :: Clubman Talk (2008+)
Jan 11, 2009 07:28 AM
