Gaskets for Xenon Ballasts?
Old Jan 24, 2018 | 06:51 PM
Cab00se's Avatar
Cab00se
I picked up a used set of xenon lights for my 2011 MCS and the ballasts I just received did not include the gaskets to seal them to the headlight. Does anyone know where I can get this gasket, I'm not having much luck tracking them down.
Old Jan 25, 2018 | 08:44 PM
Cab00se's Avatar
Cab00se
Ah man this isn't promising....can these be bought separately from the lights?
Old Jan 26, 2018 | 02:41 PM
Nope, not that i know of an its higher temp gasket also being near that housing, but i dont know what type.
63117356250
https://www.ecstuning.com/Mini-2011-...enon_Hardware/
Also if it does not seal and water gets in there it will mess up the ballast and possible to ruin it.
Old Jan 26, 2018 | 07:31 PM
Cab00se's Avatar
Cab00se
Hmm well those look nothing like the ballasts I have, and that's super unfortunate :( .....
I guess if I can't track one down I may have to try to make a gasket.
Old Jan 29, 2018 | 12:16 PM
What does your look like?
Old Jan 29, 2018 | 12:19 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Get in touch with the crew over at The Retrofit Source. They often salvage OEM headlights, and they might be able to help you source a replacement gasket.
Old Jan 29, 2018 | 02:51 PM
Cab00se's Avatar
Cab00se
Part number 1307329153
Everything I found said these were the OEM part numbers.
Old Jan 29, 2018 | 02:53 PM
Cab00se's Avatar
Cab00se
I shot them an email, worked with em in the past. Hopefully they have something.
Old Jan 29, 2018 | 02:55 PM
This one?
https://www.ecstuning.com/b-oe-after...ast/bl190~oea/
Old Jan 29, 2018 | 03:01 PM
Cab00se's Avatar
Cab00se
That's the same design yup.
Old Jan 29, 2018 | 07:01 PM
Cab00se's Avatar
Cab00se
Well I got the actual headlight assemblies today and it looks like the ballasts I was sold as fitting my car are nowhere near close so those will be going back, and just my luck at least one of the projector assemblies inside the headlight broke off one of the mounting points so it's bouncing around inside the light held on only one side....
Maybe this Mini just isn't meant to have projectors lol.
Alpha Motoring
Dec 9, 2015 09:17 PM
navybsn
Mar 28, 2015 08:12 PM
daonlyillwiz
Feb 19, 2015 07:42 AM
Carmichael
Mar 26, 2013 10:47 PM
