Error code: 287D -- Intake camshaft actuator
Old Mar 2, 2018 | 02:02 PM
BlueRidgeMini's Avatar
BlueRidgeMini
I received the following response from a local mechanic: "The code you have is 287D which is the intake camshaft actuator. There are screens in the actuator that are missing and have apparently gone up into the engine. We have had some luck with replacing the actuator and it fixes the problem. It's about 4 hours labor and the parts are a couple of hundred dollars, that's about $750 with diagnosis, parts, and labor. If this does not repair the problem and the code returns, you are looking at having to replace the timing chain, adjusters, guides, etc. This would cost about $1850 (in addition to the $750 repair).
2009 Mini Cooper Base
I would appreciate any thoughts on the mechanic's recommendations and quotes.
Old Mar 6, 2018 | 06:17 AM
MiniToBe's Avatar
MiniToBe
outrageous numbers!!!
did they actually did the work? if not, take the car to another mechanic for a second opinion.
check this:
https://www.northamericanmotoring.co...code-287d.html
https://www.newtis.info/tisv2/a/en/r...mshaft/FuW0XvK
https://www.newtis.info/tisv2/a/en/r...mshaft/4SA875M
https://www.newtis.info/tisv2/a/en/r...ontrol/FsoLOtm
preme123
Mar 3, 2026 07:47 AM
RatRacer
Dec 7, 2016 06:50 PM
fulhse
Feb 12, 2016 12:05 PM
AaronTalks
Jul 19, 2013 04:48 PM
polarstar
Oct 19, 2012 02:43 PM
