oil leaking under Eccentric Shaft Sensor
Old Feb 12, 2018 | 05:44 PM
jamadeus's Avatar
jamadeus
I'm sorry if it's already posted, but my search for Eccentric Shaft found no threads for my issue..
My situation is that I did an engine head job and after I put everything together, I noticed oil residue near the thermostat. I checked and it was under the sensor and I replaced the o-ring, but still leaking.. Do I need to replace the whole sensor? Anyone had issue like this? Also I can't find any info on the torque on the 3 bolts.
Your help would be greatly appreciated.
thanks.
jh
Old Feb 13, 2018 | 06:45 AM
MiniToBe's Avatar
MiniToBe
https://www.newtis.info/tisv2/a/en/r...-gear/D7PyNBBi
Old Feb 13, 2018 | 08:15 AM
nkfry's Avatar
nkfry
Clean the mating surfaces and apply a skim coat of black RTV to the surface of the head and reinstall the sensor.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 14, 2018 | 04:28 PM
jamadeus's Avatar
jamadeus
Thanks, guys.
nkfry, let me try that.. I did applied light layer of silicon adhesive last time, but didn't help.
Maybe the torque setting might help.
jh
Old Mar 10, 2019 | 06:50 PM
mkov608's Avatar
mkov608
Mine is doing the same thing ... just replaced all my valve guides and planed the head. I used the o-ring that came with the head gasket set, and it leaked. Ordered another O-ring from FCP Euro, same leak. Torqued to spec 88 in lbs. When I pulled it apart, there was no sealant on the sensor flange ... just the o-ring.
ColonialHoo
Jun 19, 2021 08:30 PM
deschodt
Mar 31, 2016 12:37 PM
gumbydad
Jun 15, 2009 03:22 AM
