Chain tensioner
Old Mar 10, 2018 | 07:57 PM
Ian.arroyo's Avatar
Ian.arroyo
Chain tensioner
I have a mini cooper r56. I installed the chain tensioner and when I went to start it did not start and an exclamation point appeared on the board. Why will not it start now??? Please someone help me!!!!!
Old Mar 11, 2018 | 08:27 AM
MiniToBe's Avatar
MiniToBe
S or non s. Where're you located.
Check your work again. Maybe missed a wire or plug.
Also verify that the car did not loose timing. Finally, rotate engine by hand clockwise to check movement and timing.
Old Mar 11, 2018 | 11:16 AM
Ian.arroyo's Avatar
Ian.arroyo
Its S model, im located in jacksonville FL
Old Mar 12, 2018 | 10:10 AM
MiniToBe's Avatar
MiniToBe
did you get a chance to recheck your work to see if anything is missing/not connected?
did you recheck the timing?
weaver9000
Sep 14, 2015 05:48 PM
daonlyillwiz
Feb 4, 2014 06:28 PM
gbfan10
23
Dec 12, 2012 08:26 PM
5810
Nov 17, 2010 10:49 AM
