09 mini S convertible round fob&start/stop button
Old Mar 18, 2018 | 04:35 PM
WallyOK's Avatar
WallyOK
My daughter has a 2009 Mini Cooper S standard shift with round keyfob inserts into dash with a push button start/stop. The car was running perfect she went to the store shut it off, come back out put the fob in push the button only a click and can hear the fuel relay running. All lights, power windows, radio, and everything work perfect but won't start. Its a standard so we can push start it and it will run fine. I figure it's either the fob switch, the starter, it's not the clutch switch in the cylinder checked that for contact from another post. Any recommendations. I just had to put a new clutch in it a couple months ago, so i would like to DIY this so I don't have to shell out a bunch of cash again if i don't have to.
Old Mar 18, 2018 | 05:17 PM
MiniToBe's Avatar
MiniToBe
If you can pop the clutch to start then one of two, weak battery or dead starter.
I would also check ground strap connection and battery terminal connections for being loose.
Old Mar 18, 2018 | 06:47 PM
AZdsrt's Avatar
AZdsrt
Yep, battery..
Old Mar 18, 2018 | 08:52 PM
RUPNOK's Avatar
RUPNOK
Put the battery on a trickle charger. Then load test it.
Old Mar 19, 2018 | 06:30 AM
WallyOK's Avatar
WallyOK
I checked the connections and everything is tight, I will charge and try when I get home this afternoon and see what we got.
Thanks everyone for your posts I appreciate it.
bahman
Nov 5, 2016 01:14 PM
malsalah
Oct 24, 2016 05:39 AM
rockyclm
Oct 9, 2016 10:02 PM
rockyclm
Oct 9, 2016 09:44 PM
Davbret
Aug 19, 2005 02:17 PM
