Suspension issues
Old Jan 16, 2018 | 05:47 PM
kromerok's Avatar
kromerok
Suspension issues
Ok, so I think the car hit a curb as the wheel is touching the shock
Where the wheel impacted the shock
When you turn the wheel the screw below and to the right of the circle opening is touching the frame.
Ive never worked on suspension and would like to know where i should be looking so i can know which parts to search for on youtube
Thx
2014 Mini Cooper S Conv
Old Jan 16, 2018 | 06:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Looking at that strut I would replace it first as it is clearly damaged. After that mount the wheel and see if you have clearance between it an the tire. If you do it was just the strut. If it is still hitting you need too look at the steering knuckle and lower control arm.
The lower control arm is usually pretty easy to see if it is bent. So if it looks good it is likely the knuckle.
You may also consider just doing a set of shocks like the KONI FSDs to improve the ride while doing the repairs.
https://www.waymotorworks.com/koni-f...5-r56-r57.html
Old Jan 17, 2018 | 09:02 AM
kromerok's Avatar
kromerok
I just took a look at it today and am concluding the strut and control arm for sure need to be replaced not sure about the knuckle.
Old Jan 17, 2018 | 10:57 AM
Fly'n Brick's Avatar
Fly'n Brick
Take a hard look at the wheel too. If it's bent, here's a link to an outstanding outfit that has a mobile rig to re-true any wheel. I've used them twice with great results.
http://www.awrswheelrepair.com/
Old Jan 17, 2018 | 02:50 PM
kromerok's Avatar
kromerok
Oh cool, nice. Thx
Old Jan 18, 2018 | 05:33 PM
kromerok's Avatar
kromerok
Finally got the strut out. Wow, that took a long time. trying to get the control arm out now. Cant find any videos on youtube but still trying.
Old Jan 22, 2018 | 09:28 AM
kromerok's Avatar
kromerok
Does anyone know if the only way to access the control arm bolts to remove from driver side is to lower the subframe?
trailrated
Dec 13, 2021 09:10 AM
miniglenn
Jan 31, 2008 04:10 PM
