clunk from front suspension over uneven roads
Old Feb 9, 2018 | 10:08 AM
adam7788's Avatar
adam7788
I have an R56 Cooper s 2007 Auto, that has developed a clunking when going over uneven surfaces as low speed. Its a rattle type clunk as if something loose in suspension. Tie rods are replaced, drop links replaced today and still it persists. Any ideas?
Old Feb 9, 2018 | 10:26 AM
nkfry's Avatar
nkfry
I've been installing front sway bar bushings on these cars more and more over the past few years.
Jack the front of the car up, remove one wheel, and grab one end of the sway bar and push/pull the bar back and forth, chances are that's where your clunk is.
If you find that those are the failure point, you'll need the 24mm bushings:
Powerflex Sway Bar Bushings
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 9, 2018 | 10:55 AM
adam7788's Avatar
adam7788
This is my current thought too - are they really difficult / expensive to get done though?
Old Feb 9, 2018 | 11:52 AM
nkfry's Avatar
nkfry
The parts themselves aren't too expensive, but you need to drop the subframe to replace them. We charge about $300-350 to replace them, but if your subframe is going to be down I would take the time to do the front control arm bushings as well. They're probably not bad, but for $86 in parts and a little more labor they'll never need to be touched again.
Phone:586-792-6464
Old Feb 9, 2018 | 02:38 PM
ShipM8's Avatar
ShipM8
All roads are uneven (at best) where I live! Good luck with finding the right fix.
Old Feb 9, 2018 | 02:42 PM
shanksamillion's Avatar
shanksamillion
It could also be your sway bar links. The lower control arm bushings are most likely. The sway bar bushings less likely but still very possible.
Old Feb 10, 2018 | 04:54 AM
TorchMINI's Avatar
TorchMINI
I had to replace ball joints and shocks to get rid of my clunking, in addition to the listed items above (at around 80,000 mi).
Old Feb 15, 2018 | 10:46 AM
adam7788's Avatar
adam7788
Sway bar links have been done. Just a thought - I changed a wheel bearing recently and jacked up only one side to do it. Is it possible that by undoing control arms etc and putting back together with only one side jacked up, that I created an imbalance in the suspension tensions when put back together. Should both sides be jacked and on axle stands when working on suspension - due to stresses and load etc. I ask, because it seems like this really only started after the wheel bearing replacement . Thoughts?
Old Feb 15, 2018 | 12:43 PM
nkfry's Avatar
nkfry
Loading the suspension unevenly shouldn't have had anything to do with this; if the noise began after you worked on the car I would recommend retracing your steps to make sure everything is tight.
If you feel like doing a quick check, jack up the front end (both sides) take off one wheel, grab the sway bar and try to push it side to side across the car, if there is an audible clunk or you feel any lateral play the bushings are bad.
Phone:586-792-6464
Old Feb 15, 2018 | 03:01 PM
gumbedamit's Avatar
gumbedamit
My bad, misread the post.
Old Feb 15, 2018 | 03:18 PM
shanksamillion
Usually you want to jack up the whole axle when working on suspension. It helps the bolts line up because you are right, the load on one side will mess up your bolt holes a bit. Things won’t line up. Like if you were replacing the shocks, that lower bolt hole won’t line up. I know because this happened to me. In your case though I don’t think it will matter. So if you’ve already replaced the links and the sway bar bushings you need to look at replacing the lower transmission mount. There is a TSB on this “clunking” noise. The reported fix is sway bar bushings and transmission mount. Good luck!
Old Feb 16, 2018 | 12:36 PM
adam7788's Avatar
adam7788
Interestingly, the temperature has increased 6-10 degrees over the last 2 days (in UK) and it appears to have almost disappeared. Its been freezing or around zero since I bought the car. 6 weeks ago. This reinforces my thought that its bushes somewhere?
Harbor
Jan 30, 2018 06:34 AM
SuzyF
Aug 17, 2012 08:24 PM
ksminiman
Dec 13, 2010 01:50 PM
spurvis
Jan 31, 2008 08:52 AM
LordOfTheFlies
Suspension
Jan 28, 2007 05:08 PM
