My 2011 countryman S yellow engine lights on and has no power under a load code p0304
Old Feb 19, 2018 | 10:06 AM
ChopperDan's Avatar
ChopperDan
at first the jerking started when accelerating,
now the yellow lights are on and when the car is idling it runs like a champ but under a load no power, the code is p0304 I changed the coil from 4 to 2 and it didnt make a difference what else could it be, love my mini but have had too many problems only 53000 miles and have spent a small fortune in repairs, has anyone else had this problem Thanks Dan
Old Feb 19, 2018 | 10:46 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
First you posted in wrong section, Clubman not Countryman.
Plugs, coils and then High Pressure Fuel Pump seem to be common areas of concern. 2011 Countryman HPFP would be covered under extended program by MINI but they will need to diagnose and confirm that.
Old Feb 20, 2018 | 05:19 AM
MiniToBe's Avatar
MiniToBe
+1
also, did you swap spark plugs>?
rumcuredcrook
31
Dec 29, 2018 07:30 AM
azcountryman
R60/R61 Stock Problems/Issues
Mar 13, 2018 09:52 AM
Garcia242
Mar 8, 2018 08:17 PM
Shawn C
Jan 21, 2018 11:14 PM
ig109
11
Jan 18, 2018 04:33 AM
