R60 2011 Countryman.. Removed battery now no volume button response
Old Jan 8, 2018 | 04:21 AM
ig109's Avatar
ig109
So over the weekend I was installing a trailer light controller in our Countryman.. This required pulling a power wire from the battery to the boot. In doing so I removed the battery, and glove box from the vehicle. I pulled a single 10ga wire with a fuse to the rear area.. capped it all off after realizing that the trailer converter was the incorrect one.
Anyway.. After all this I put the battery back in the vehicle.. restarted fine.. No codes.. However neither volume button seems to have a response to the radio.. The radio powers on fine.. Seeks and finds stations fine.. But neither volume button works.. Power button on the volume button even works..
Fun side note.. The temperature here has been below 0 for several days in the past weeks.. I did this work in the garage with the propane salamander burning.. Had a fan blowing air into and out of the mini.. Doors and windows were open so that the whole thing could come up to temp..
In the midst of all the temperature change the dash near the HVAC / glove box began to develope frost..
Can anyone think of anything that I would cause this?
Battery was disconnected ground side first.. and installed same way..
Are BMW's this sensitive or have I done something badly wrong..
Old Jan 8, 2018 | 04:33 AM
ig109's Avatar
ig109
Guess I should add that I tried to use the Aux input for the first time at this same time..
I had my android plugged into the USB to charge and the AUX for audio..
Not sure if this could do it too or what..
Old Jan 8, 2018 | 06:39 PM
ig109's Avatar
ig109
100 views and nobody has any ideas..
That doesn't give me much hope
Old Jan 8, 2018 | 06:59 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
HK or basic system? HK amp in back maybe disturbed a wire? How about cd or usb source, same volume issues?
Old Jan 9, 2018 | 08:03 AM
ig109's Avatar
ig109
Harmon Kardon.. Only work anywhere near the amp was removing and reinstalling a nut on the lower rear bracket.. had intentions of using as a ground point but didn't since the adapter didn't work..
USB no response.. Have yet to try CD.. Aux won't respond either
Old Jan 9, 2018 | 08:53 AM
Minnie.the.Moocher
I recall reading on a BMW forum of this happening and the answer was disconnecting the negative battery terminal for 1/2 hour or so and that would reset the issue. Worth a shot.
Old Jan 9, 2018 | 08:54 AM
ig109's Avatar
ig109
Going to try that when I get home
Old Jan 9, 2018 | 07:28 PM
ig109's Avatar
ig109
Well tried the battery disconnect.. left sitting for an hour. Reconnected. Nothing. No chimes. No response from the radio when I turn volume ***.. nor when I use the steering wheel volume controls.. are the head unit in these the same as the Cooper ones? What about the amp?
Local boneyard has a low mile copper S that has Harmon stereo..
More curious as to how this happened as I am how to repair. The radio comes on.. seeks fine. No sound and no volume control.. please offer up any more things to check
Old Jan 9, 2018 | 07:54 PM
Minnie.the.Moocher
Did you check the fuses?
https://www.northamericanmotoring.co...-decoding.html
Old Jan 10, 2018 | 04:06 AM
ig109's Avatar
ig109
Checked them when the issue first occured.. They look ok but I haven't checked with DVOM
Old Jan 12, 2018 | 06:50 AM
ig109's Avatar
ig109
Fuses all check out ok..
Went to local salvage yard and pulled a radio from a car.. It's sitting in my pile of spares.. However Upon departing said salvage yard I got ONE sign of life.. The stereo emitted one and only one bing bong to tell me my belt was off.. Then silence again..
Still no volume response..
The warning chimes are all even gone..
Anyone have anymore suggestions before I pull the dash apart..
Can anyone confirm the fuse for the HK amp in the countryman.. seems even in the link above there is some confusion.. My car isn't wired with anything in F5 and that is the one it calls out.
Thanks,
Old Jan 18, 2018 | 04:33 AM
ig109's Avatar
ig109
Just in case anyone was following this for an answer.. It seems that while in the garage on that fateful day the snow / ice that was in the driver floor must have melted.. and gotten into whatever electronics down there deal with the radio function.. Didn't think the FCM had anything to do with audio but I guess I must be wrong.. vacuum water out.. put fan in floor over night.. radio is fine..
Get in with snowy boots.. once they melt and it runs into carpet.. radio dies.. Guess It's time for some weathertechs and some water intrusion protection..
liv_loud
Electrical
17
Sep 15, 2024 08:07 AM
swaginwagon
Sep 1, 2011 11:05 PM
New2MeMiniS
Mar 22, 2010 10:51 AM
supermini78
Jan 24, 2010 05:57 PM
BritBoy
Oct 29, 2009 11:01 AM
