Hi can someone id this warning for me?
Old Sep 20, 2011 | 05:20 PM
Oakland Raiders Mini's Avatar
I lost my owner's manual. This is for a an 07 MCS Thanks in advance.
Old Sep 20, 2011 | 05:24 PM
boostin's Avatar
boostin
just a warning light
this light is because your car thought you had a flat tire or that you do have a flat tire if you dont have a flat you can just reset the light there should be a button to press that looks similar too that light on my 06 mcs it is next to the ebrake handle
hope this helps
Old Sep 20, 2011 | 05:28 PM
ThumperMCS's Avatar
ThumperMCS
Tire Pressure Monitor...check tire pressures, then reset it by using the OBD computer which you access through the end of the wiper stalk.
Old Sep 20, 2011 | 05:52 PM
hsautocrosser's Avatar
hsautocrosser
The manual is online at MINI's free owner's lounge:
https://ol.miniusa.com/auth/ViewMINI...NI_Hardtop.pdf
Old Sep 20, 2011 | 06:45 PM
PatM's Avatar
PatM
If you rotated your tires you will need to reset. This will come up every time you rotate.
Old Sep 21, 2011 | 04:59 PM
Thanks once again for the help. Sure doesn't look like a tire.
randeez
Oct 5, 2015 09:23 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
