Timing Chain problem fixed? As of When?
Old Jul 12, 2011 | 05:46 AM
Aether's Avatar
Aether
Since I've asked this questions a couple of times in the "Timing Chain Issues" thread and haven't received any type of response, let me try it in a new thread....
Does anyone know if there's a current fix that definitively solves the timing chain tensioner issues and if so, has this been implemented in the assembly line and as of when (i.e. are 2011s - or will 2012s be - susceptible to this issue)?
Old Jul 12, 2011 | 06:16 AM
ZeR0 EVOlution's Avatar
ZeR0 EVOlution
As of right now, Mini alleges that they've "figured it out," but I personally don't know anyone that has had the job done. I'm currently getting my problem fixed and should have my car back by Friday, but it could be months or years before I find out if the fix was a sure fire thing.
Old Jul 12, 2011 | 08:06 AM
DneprDave's Avatar
DneprDave
There was a service bulletin, SI M11 0207, dated September 2010, entitled, Rattle Noise from Engine. It recommends changing out the timing chain tensioner on cars with a timing chain caused rattle, built before May 4, 2009. In some cases it also says to change the chain and guides.
From what I've read on these forums, there was also a problem with tensioners on some 2010 engines, that weren't torqued at the factory and can back out. It is a small number of the engines with the improperly torqued tensioner. It is as if someone at the factory was not doing his job.
It is real easy to check the torque of the timing chain tensioner, it takes a 27mm socket and it should be torqued to 65 nm.
Another NAM member changed his out himself and posted a nice pictorial,
https://www.northamericanmotoring.co...tensioner.html
Dave
Old Jul 12, 2011 | 12:54 PM
kwd's Avatar
kwd
I had my timing chain; tensioner and gears replaced on my 2007 MCS back in March this year and just like Dave said there was a Rattle Noise coming from the Engine, mostly when engine was cold. I took it to the dealer still under warranty, barely 48500; they proceeded to change out the timing chain, tensioner along with gears. This was definitely the main cause of engine rattles. Now the million dollar question, how long wills this one last?
Keven
[FONT=Calibri] [/FONT]
Old Jul 12, 2011 | 06:35 PM
10Zero's Avatar
10Zero
Problem was apparently resolved and the new parts utilized in engine builds beginning late Feb early Mar of 2009. I don't believe there's any "death rattles" in very late 09s and on. DnprDave is right though, seems there's been a select few that had the tensioner bolt back out on them....but VERY few.
I'm driving a 2010 built 09/09....solid as a rock.
Old Jul 12, 2011 | 07:37 PM
MP1.6T's Avatar
MP1.6T
+1 to last several responses
Same way I have read the available info.--particularly the supposed prior resolution, but then this production line screw up that may have bled over into the 2010 builds with someone/some tool that couldn't perform a no brainer/"any trained monkey could do it" type function.
Likewise I have an early 2010 also built in 9/09 and see or hear no evidence of the issue. Read the service bulletin and concluded it didn't apply to my (later) build date. Have visually looked at tensioner area and see no signs of looseness, oil seepage, etc.
Originally Posted by 10Zero
Problem was apparently resolved and the new parts utilized in engine builds beginning late Feb early Mar of 2009. I don't believe there's any "death rattles" in very late 09s and on. DnprDave is right thought, seems there's been a select few that had the tensioner bolt back out on them....but VERY few.
Old Jul 12, 2011 | 07:55 PM
oldsbear's Avatar
oldsbear
2011 builds have a different valve management system, which is said to have eliminated the timing chain (Cold Start or Death Rattle) problem. motoringfile.com has articles describing improvements made for the 2011 Life Cycle Impulse.
Here is one article:
http://www.motoringfile.com/2010/05/...ines-in-depth/
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
