Intermittent CEL
Old Jul 18, 2011 | 09:04 AM
jrunner192's Avatar
jrunner192
Intermittent CEL
All,
I have encountered an unusual CEL issue. The day that my warranty ran out (of course) I was accelerating on the highway (engine under high load) and my CEL came on with the noticeable reduction in power (limp-home mode). Instantly checked to make sure the gas cap was tight as one might expect and it was fine. Then I thought it might just be a tank of bad gas so I waited to refill it with some better Shell 93 octane and that did fix it either. The unusual part is that it is intermittent. I can go several trips in the car without it coming on and it drives perfectly, but I put heavy load on the engine and it comes back on and cuts the power. I tried having the code read at Autozone with one of their little readers but it didn't show anything coming up, even with the light illuminated. Short of bringing it into the dealer and having them diagnose it for me, any thoughts on what could be causing this?
Thanks ahead of time.
Old Aug 14, 2011 | 01:36 PM
jgillespie's Avatar
jgillespie
My '07 MCS is doing the same thing. Yellow CEL on after heavier acceleration. When you turn the engine off then on again it goes off. Anyone have the same problem.
Old Aug 30, 2011 | 06:31 PM
kraptor's Avatar
kraptor
Same issue here! WTF!!!! :(
Old Oct 12, 2013 | 07:51 PM
pmikulencak's Avatar
pmikulencak
I am having this issue, were there any solutions?
Old Oct 12, 2013 | 08:06 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Save yourself some time and money and get the code.
Could be anything from a faulty pressure converter, electric valve or bad turbo.
Old Oct 12, 2013 | 08:09 PM
pmikulencak
Nearest dealer is two hours away. Autozone reader gave no code, same for advanced auto parts. Found one error in hidden menu, it was 9314h. Can not find any direction ogf what that may be.
Old Oct 12, 2013 | 08:35 PM
-=gRaY rAvEn=-
Moderator
Check with someone in this club.
Maybe they can point you in the direction of a shop learned in MINI repair.
https://www.northamericanmotoring.co...-kool-aid.html
neezebeeze
Oct 31, 2016 12:10 PM
rob&JCW
Oct 9, 2015 11:12 AM
potterstein
Oct 2, 2015 09:30 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Nick Royer
Sep 16, 2015 08:17 AM
