Engine Light
Old May 28, 2011 | 06:30 PM
largar62's Avatar
largar62
Engine Light
Hello I have a 07s Automatic. at 40,000 miles my engine light came on and was running rough. Minni said I had carbon build up I asked how they deal with it and they said the manually remove it. I now have 45,000 miles and the light came on again and its starting to run rough. Is this somthing thats going to continue. I use 93 octane and Im not shy with the throttle. Is any one else having the same problem. Or has anyone been able to fix this for good
Old May 28, 2011 | 08:00 PM
orangecrush's Avatar
orangecrush
A couple of thoughts...
Where is the carbon buildup? Valves? You mentioned the dealer had to manually remove it, I can only assume they took the head off and cleaned the valves?
Regardless, there are two things I would think about.
1) a tune... a tune will make the car run better but also, usually much leaner than stock.
2) if you don’t do a tune, then I’d at least buy some BG or some sort of fuel or oil additive... surely it would be cheaper than paying to have the valves cleaned.
Mark
Old May 29, 2011 | 09:58 AM
Fly'n Brick's Avatar
Fly'n Brick
+1 on the BG44K. One can then fill the tank and repeat about every 6 months. You WILL see a difference.
Old May 29, 2011 | 11:07 AM
highlander709's Avatar
highlander709
BG ???? Opinions on Seafoam?
Etrain
16
Aug 5, 2024 04:37 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
