Stall? WTF!?
Old Sep 29, 2011 | 11:44 AM
Nerotrobe's Avatar
Nerotrobe
Stall? WTF!?
I bought a 2008 Mini Cooper w/ 6 speed manual transmission early this month, and haven't had any problems with it until today.
I was in 1st gear attempting to pull away from a stop sign, when the car stalled. It almost seemed like the throttle response was suddenly different, as the normal amount of pressure on the petal didn't seem to give the engine the amount of throttle it needed to move.
Any ideas what might cause this?
Old Sep 29, 2011 | 12:58 PM
6speedwtneed's Avatar
6speedwtneed
Just a one time thing or is this permanent now?
Old Sep 29, 2011 | 01:43 PM
gkp's Avatar
gkp
Could be the high-pressure fuel pump on its way out -- a known MINI problem that any dealer will fix under warranty. The warranty on the pumps was extended to 100k miles. See if it happens again and with more frequency.
Old Sep 29, 2011 | 02:00 PM
tippykayak's Avatar
tippykayak
If it was a single time thing, it could just be that you pulled out the clutch a hair too early. Then, once you throttle, the engine's unable to get going.
Old Sep 29, 2011 | 02:03 PM
ACEkraut11's Avatar
ACEkraut11
I wouldn't worry too much about it unless it starts happen more than once.
Old Sep 29, 2011 | 04:01 PM
JimR56JCW's Avatar
JimR56JCW
Press the sport button. It helps eliminate this problem.
Old Sep 29, 2011 | 04:10 PM
Nerotrobe's Avatar
Nerotrobe
thx
Thank you for all of the replies. I realized later that I don't remember pushing the sports button, so it's very possible that I didn't give it enough throttle because I was expecting a more responsive throttle response.
It's good to know about that high pressure fuel pump warranty extended to 100,000 miles, I wasn't aware of that, is there a source online that I can read about that?
Old Sep 29, 2011 | 04:12 PM
drewstermalloy's Avatar
drewstermalloy
It was probably just an accident caused by your left foot. I stall my car about twice a year when I'm not paying attention.
drewstermalloy
Do you have an MCS or a Cooper? If it's a Cooper then you don't have the fuel pump issue.
Old Sep 29, 2011 | 04:27 PM
Nerotrobe's Avatar
Nerotrobe
It's a Mini Cooper, not a Mini Cooper S.
Old Sep 29, 2011 | 10:07 PM
Btwyx's Avatar
Btwyx
I have that problem if the sport button isn't on.
Old Sep 29, 2011 | 10:26 PM
dannyhavok's Avatar
dannyhavok
I had a 24H test drive in an '08 S. I forgot to turn the sport button on after stopping somewhere for a few minutes, and immediately stalled it. Oops. I don't know why that button is there, it should always be ON. When I was a kid I had a 386 computer. It ran at 16MHz, but if you pressed the "Turbo" button, it would overclock to 33MHz. Who wouldn't have it on all the time?
Old Sep 30, 2011 | 04:39 AM
richardsperry's Avatar
richardsperry
That's why there is a AutoSport Module form FES...
Markbett
Jul 3, 2016 04:28 PM
mimaal
Sep 4, 2015 09:09 AM
bmanrkg3
Aug 29, 2015 09:34 PM
cornfly888
Aug 24, 2015 09:57 AM
Steffen.Johnson
Aug 23, 2015 08:30 PM
